How long do you run your chains?
Discussion in 'Chainsaws and Power Equipment' started by Bgoathill, Oct 30, 2016.
  1. Bgoathill
    Bgoathill
    Dumont, Ia
    I have quite a few older chains, say 10 to 15 years old. As I was sharpening some today I noticed a few were getting a bit of slack in the links. I have enough to keep swapping out so each one only gets sharpened 2 or 3 times a year. They still have quite a bit of tooth left.
  2. Firewood Bandit
    Firewood Bandit
    Well when the cutters are little bitty triangles, they are shot.
  3. Will C
    Will C
    New York
    Never had any get like that. I use them until I can't get a good sharpening. Usually when there is 1/3 to a 1/4 tooth left, I've messed up the angles enough I can't get it sharp. Could use a guide, but it is easier to just put a new chain on-it means I go through 3-4 chains a year, and I'm ok with that.
    Woodsnwoods, Hammy and clemsonfor like this.
  4. lukem
    I scrap a couple a year. I probably get one winter's worth of wood out of a chain...less if I try to cut through metal or rocks.
  5. T-Stew
    T-Stew
    Are you guys cutting through nails or just cut a massive amount of wood? I've yet to go through a single chain in 8 years, that's 2 of the safety chains that came with the saw and 1 more aggressive one I bought and mainly use the last few years. They all look pretty much like new as well, except I broke a tooth on the newer one but it still cuts good so I keep using it. I may not cut as much but still probably 3-4 cords / year up until last year.
    Woodsnwoods, Hammy and 94BULLITT like this.
  6. Will C
    Will C
    New York
    You got me thinking so I checked my chain box. I went through 2 20" chains and 2 16" chains last year. That was cutting around 15 or so cords, as well as odd jobs with the saws.
  7. saskwoodburner
    saskwoodburner
    I think I killed my first chain in about 8-10 cords. That was near the end of my second year cutting if I recall.
    Woodsnwoods and Hammy like this.
  8. clemsonfor
    I grind so it takes more than hand fileing.
    BUT I don't use several chains a year. and I cut around 2 to 4 cords a year.
    I use them till teeth start breaking off in small triangles.
    If rivets are loose I would scrap the chain. I would not want any busted chains flying off.
    Woodsnwoods, thistle, Hammy and 3 others like this.
  9. CTYank
    CTYank
    CT Panhandle
    My experience has been that frequent very light filing with guided file helps make chains last a verrrrrry long time. I'd hate to even guess at the numbers. Properly-kept chains seriously boost longevity of bars too.
    When a chain has spit enough teeth so it doesn't cut any more, it gets recycled and thanked for a lifetime of work. On occasion, before it gets to that point, a chain may be designated a "stumper" for its last assignment or two. Only a couple chains have gone these routes in the last five years.
  10. bogydave
    I use my older ones for stumpers & trail work.
    I put an old bar on then too.
    Woodsnwoods, Hammy, Mag Craft and 3 others like this.
  11. clemsonfor
    For sure a constant sharp chain keeps the bar cooler.
    Woodsnwoods, Hammy, CTYank and 2 others like this.
  12. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I use them up completely I can get them to tiny little teeth so close one more sharpening will probably break the teeth. They get that last sharpening then get thrown in the just in case box. In terms of how long that just depends on how much I am cutting.
  13. CoreyB
    CoreyB
    South east iowa
    Until I can't lol
    Woodsnwoods, Hammy, CTYank and 3 others like this.
  14. tamarack
    tamarack
    paulina oregon
    I only run them till there about 60% worn out. Then i sell them to a friend who cuts alot of juniper. He also has a nice grinder so he gets em straightend out real nice.
  15. Barcroftb
    Barcroftb
    The Mitten
    I run mine until they have little bibits of triangles left of the top plate. I have done so for decades and thousands of trees.
    Generally when a couple teeth break off the chain is junk. Look at a race chain sometime and you will see just how far a chain can be pushed!
  16. Khntr85
    Khntr85
    Well said sir....I also feel like I am constantly touching up chains....but I when I hit the woods I like to get to cutting and know my chain is a good as it can be... just seems easier in the saw in general to have a sharp chain!!!
  17. Jon_E
    Jon_E
    Southwestern Vermont
    I'm pretty close to using up my first chain with my small Dolmar. I have probably cut close to 100 cords of wood with the chain that's on it, including quite a bit of black locust. I hand file with a guide so not a lot gets taken off the chain each time, and I am pretty diligent about sharpening after every two tanks of gas no matter what I am cutting. Sometimes only one tank if in dirty or abrasive conditions, but never more than two. Even two or three light strokes on each tooth makes a world of difference and it only takes a few minutes. I do keep spare chains for any combo of bar and saw I use, but I'd rather sharpen in the field than swap chains. After a weekend worth of cutting I'll usually pull the bar and chain anyway and give the saw a cleaning, get all the accumulated crud out of the nooks and crannies.
    Woodsnwoods, CTYank and Khntr85 like this.
  18. DexterDay
    It isn't shot until you lose a couple teeth!! ;)
  19. Mag Craft
    Yep I just tossed one today because the cutters have become so short that the teeth were braking off. I did use for stumping a couple of small trees which did not help.
    Woodsnwoods, clemsonfor and Hammy like this.
  20. Butcher
    Butcher
    Well Travis, my rivets are all slack but I'm getting pretty short in the tooth department so I guess I aint gonna get no sharper.:D Did you find a home for that calf?
    Woodsnwoods likes this.
