Leaking bad need help please
Discussion in 'Chainsaws and Power Equipment' started by Thor, Oct 27, 2016.
  1. Thor
    Thor
    Genoa City,Wi
    These 2 fittings are dumping fluid big time. I can move the whole valve. I think my buddy hit it with something. When I tear it down what should I use to seal it. I was told not to use Teflon tape.
    Seems like a poor set up. I can't believe. How easy it is to move the whole valve. Thanks in advance for the information guys!
    clemsonfor and Woodsnwoods like this.
  2. Canadian border VT
    my recommendation and not a nechanic.. is drain it first.. pull the line there should be some of rings in there replace those.. then I use pipe dope for hydraulics available at any hardware store or tractor supply.. if you just want to patch it I have done that with lok tite hydraulic
    Woodsnwoods, Well Seasoned and Thor like this.
  3. Thor
    Thor
    Genoa City,Wi
    No o-rings. I'll clean it up and dope it up and hope for the best.
    Woodsnwoods and Well Seasoned like this.
  4. JustWood
    JustWood Guest
    Is that 3" pipe nipple between the valve and cylinder the only thing supporting the valve bank????
    If so that's a prime spot for failure due to vibration and wear from activating the valve.
  5. Thor
    Thor
    Genoa City,Wi
    Yes kind of a bad set up. But not sure what to do about it. I can't seem to get both fittings tight.
  6. concretegrazer
    concretegrazer
    Southwest MO
    I still use quite a bit of teflon tape. Just put it on right & clean it up if you ever disassemble. I also use the loctite sticks. Replace the worn nipple & build a support bracket for the valve.
  7. bushpilot
    bushpilot
    Eastern Washington
    Teflon tape, as much as needed.
    clemsonfor, Woodsnwoods and Thor like this.
  8. fuelrod
    fuelrod
    Western Maine
    The issue with teflon tape is sloppy use of it and getting some if into the system. Keep it away from the very end of the threads. I have not had the best results with the paste thread sealant, it seems to take forever to harden.
  9. revver6
    revver6
    mid-michigan
    loctite 545 is all we use on our heavy equipment plus all I use in my shop for hydraulic fittings.part stores will have to order it for you,not a common sealant they keep on the shelves here in mid-michigan
  10. Bgoathill
    Bgoathill
    Dumont, Ia
    If it wasn't leaking before and now it is, and if it got hit, the fittings probably got cracked. You might have to look real close to see it in side the threads.
    clemsonfor, fuelrod and Thor like this.
  11. TurboDiesel
    Once you bump a fitting loose it will leak since the pipe thread sealant was dried up.
    Use a good thread sealant like RectorSeal No. 5
    You can use Teflon tape with it also, but mentioned above, start back one thread from the end so the tape doesn't get like this
    clemsonfor, Thor and concretegrazer like this.
  12. clemsonfor
    I think my buddies splitter is that same design and fitting like that . it's some brand that starts with M... like Moehr or something like that?
    Thor likes this.
  13. Thor
    Thor
    Genoa City,Wi
    I doped it up. Worked it today. So far so good.
    cnice_37, clemsonfor and HDRock like this.
  14. Joe Seaton
    Joe Seaton
    Louisville Tennessee
    Hey Thor I have the 27 ton Dirty Hand Tools splitter. Ive had it about 6 months. I bought it from Lowes and ut was "pre assembled" at the store. I knew exactly what it was when i looked at the valve. I had the same problem abot 2 cords in and it was at the same spots as yours. I completly took the valve off and used teflon tape, being careful not to get any in the line as mentioned above and then used pipe dope on top of the teflon tape. Once I did that and reassembled it, filled it back up with hydro fluid and bled the system, no leaks since. I heard everybody with a DHT splitter was having trouble with that type of leak. Its basically because Lowes quickly assembles them and sticks them outside. They should use the teflon tape and pipe dope but they don't. I knew looking at it that it would eventually leak and it did. I just waited to take it off until the leaks started. You shouldn't have any more issues with it if you were able to get the fittings tight again. Good luck.
    clemsonfor, HDRock and Thor like this.
  15. HDRock
    Glad you got it fixed and working good  :thumbs::axe:
    clemsonfor and Thor like this.
  16. clemsonfor
    Good work. I know what to do with his. it's not a DHT spitter. he has had it close to 20 years I bet.
    Thor likes this.
