White substance ?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by ivanhoe, Oct 28, 2016.
  1. ivanhoe
    ivanhoe
    Northern Ontario
    I sprayed graphite last year around the door to cover the surface rust and now we have a white substance surrounding the door vicinity. Anyone know what it is? Is it firing too hot and the manufacturing coating is degrading? This is the Fahrenheit 50F furnace. I've burned some mixed corn with pellets last year if that helps any on troubleshooting it. Yes it's rusty inside, will spray Pam next spring:smoke:
    BAN83, IHATEPROPANE and slvrblkk like this.
  2. imacman
    imacman
    Denver, NC
    Did you scrape/sand down to bare metal before spraying the graphite? IMO, that part of the furnace probably only needs Hi-Heat paint. I used the graphite spray on exhaust fan blades, burn pot, etc., stuff that gets really hot.
  3. ivanhoe
    ivanhoe
    Northern Ontario
    When I first got the furnace I sprayed the high-heat black paint around all rusted areas. Last year I sprayed some graghite around the door so the gasket wouldn't stick. Back to the sanding and paint again. Hard to get a OEM finish:confused: which is a lot thicker:yes:
    BAN83, wildwest and slvrblkk like this.
  4. peterfield
    peterfield
    I read the title and my mind was going in a completely different direction.
    BAN83, gbreda, imacman and 3 others like this.
  5. ivanhoe
    ivanhoe
    Northern Ontario
    Wrong forum, my whoops:faint:
  6. krooser
    krooser
    Waupaca, WI
    I'm wondering who Pam is and why she needs to be sprayed...
    BAN83, gbreda, CleanFire and 4 others like this.
  7. wildwest
    Interesting. I have an Eco65, never sprayed with anything and only heat pellets put through it. I have paint finish that has come off from the body above the door hinge.
  8. bushpilot
    bushpilot
    Eastern Washington
    BAN83, imacman and ivanhoe like this.
  9. imacman
    imacman
    Denver, NC
    More coats of paint.
    BAN83 and wildwest like this.
  10. ivanhoe
    ivanhoe
    Northern Ontario
    Just did a second coat but I think the OEM is powder coated:yes:
    BAN83 and imacman like this.
  11. wildwest
    I remember admiring your pipe on your last stove, looked OEM!! Granted it was gloss, not black. Too bad there is not high temp bed liner paint.
  12. ivanhoe
    ivanhoe
    Northern Ontario
    Up to four coats and will finish with 5.
