First fire started from coals
Discussion in 'Modern EPA Stoves and Fireplaces' started by HDRock, Oct 27, 2016.
  1. HDRock
    Not a lot of coals, but just enough :fire:
    Note the piece of kindling, front bottom and a couple on top to help get er up to temp.
  2. Eric VW
  3. bogydave
    You burning 23/7 now ?
  4. HDRock
    Naw, the cottonwood burned up fast and left a little coals
  5. bogydave
    Ah
    Cottonwood,
    Now's a good time to use it up.
  6. Woody Stover
    Woody Stover
    Southern IN
    That's what I often do as well, pre-heat the box with some kindling instead of bottom-burning half of a fresh load, trying to get heat up to the top of the box so I can light the cat. Probably not as much of an issue with a tuber...
    He's probably a lot closer than I am. Almost November?? This is crazy! But I don't have a problem with it...still have some stuff I need to get done outside.
  7. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    :yes:Same here Woody. Enough to pre-heat then actually load it. Shoulder season only of course. ;)
  8. Horkn
    Same with my basswood fires now.
    It is a perfect time to use that wood though.
  9. HDRock
    Once those couple pieces of kindling on top get fired up, they heat up the top of the stove and the pipe, for a good draft pretty quick,, bottom-up top-down all in one
  10. HDRock
    Yeah it puts out enough Heat in the daytime , that Cottonwood I got was fairly easy too, backed up to a pile and loaded it
  11. Locust Post
    I may be done burning for a week or so here.....not quite as warm as Woody but close and a little rain mixed in.
  12. Woody Stover
    Woody Stover
    Southern IN
    I burned a pre-heat fire in the Buck most of the time, since I loaded on a 12-hr. schedule and stove temp wasn't high enough to load on coals and go. It take a while to get all the steel up to heat!
    If the coal bed is pretty low in the Keystone I will sometimes do the reverse of standard procedure, and go for a cleaner start. Instead of pulling the coals forward, I'll shove 'em to the back where they can't get air. Then I will load a big split on 'em, and build a top-down load in the front. Gotta change it up once in a while! :thumbs:
  13. HDRock
    I overdid it a little bit on that load, three or four beers :cheers: I guess I got carried away :whistle:
    Even though it was Box Elder house went up to 84 had to open windows:D:dex:
  14. HarvestMan
    HarvestMan
    Southeastern Michigan
    Ha Ha! Me too ... but only up to 80 here. :)
    Love those pictures of a full N/S load! As a side loader owner, I confess to having a bit of envy when I see pictures like yours.
  15. HDRock
    My old stove was a sideload, arm burner o_O, was big though, would take a 3 foot log
  16. bert the turtle
    bert the turtle
    I love to play the "no matches, no lighter" game. I just lit up from coals about a half hour ago. Had a pine fire last night, searched around in the back under the ashes for something to work with (that's where they hide in my stove). Found a fist-sized piece of charcoal with the barest spot of glow on it. A minute's work with the hatchet working up some kindling and a handful of really small stuff, a bit of work with the bellows and I'm good to go.
    I have no idea what exactly the scenario is where I'd have no matches or lighter, but I somehow feel good knowing that even in one fire a day weather, I could get by on a single match for the duration if I needed to.
  17. HDRock
    Those buggers do hide in the back :smoke:
    It is fun getting a fire goin from not much :D
  18. HarvestMan
    HarvestMan
    You just transported my mind back to my childhood where everything was once a pure innocent game - only occasionally interrupted by the noise of what we now call "reality". Thank you! :thumbs:
    Looking forward to playing this game when it gets a bit colder ... stuck in the one fire every 24 hours or so cycle.
  19. clemsonfor
    I am loading stove once a day. the coals will reignite the wood and stove is still warm. I have had half a dozen coal relights. and I am in SC:eek:
    Backwoods Savage and HDRock like this.
  20. Huntindog1
    Huntindog1
    South Central Indiana
    If I am wanting to get max burn time , I will use kindling and a Fire starter to get the heat built up really quick in the stove.
    That way I get the input air shut back down really quick and dont have to leave the door open very long.
    Works even faster with a good load of really dry wood.
