Like Ring around the collar - Ash under the impellers! Oh that dirty Ash!
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Oct 25, 2016.
  1. don2222
    don2222
    Salem NH
    Hello
    Every time I take the exhaust motor out there it is! LOL
    If a double paddle blade came in 4.75" in diameter that would keep the ash down to a minimum!!! :)
    Would a ceramic coating on the petals help?
    Is there a way to make it self cleaning?
    It would be nice to press a button and then some nylon bristles would flip down for a few revolutions and wipe it clean!
    Maybe different shape petals to direct some of the air down to wash the mounting hub like an air wash???
    See dirty pics below
    A little Dry Moly does help.
    gbreda, Gasifier, ttdberg and 2 others like this.
  2. ZBrooks
    ZBrooks
    Kuna, Id
    I put some dry moly on mine when I cleaned it last week. The ash came off pretty easy with an old paintbrush before.
    jtakeman likes this.
  3. don2222
    don2222
    Salem NH
    It will be even better now!
    I wonder if ceramic coating would be better on the exhaust impellers???
    You can get the VHT ceramic coat ultra high temp spray paint from the auto parts store and the fire the stove slowly to cure it on the blades. That would be interesting to try.
    Here is a DIY biker that did it to his Harley Exhaust! :)
    greendohn likes this.
  4. badbob
    badbob
    Yep agree with you,either ceramic or powder coat,I have done hi temp coatings on snowmobile pistons in my home oven,give it a try!
    don2222 likes this.
  5. don2222
    don2222
    Salem NH
    Cool!
    Ceramic is much higher temp than powder coat.
  6. krooser
    krooser
    Waupaca, WI
    try the kitchen oven... when the wife isn't home.
    don2222 and imacman like this.
  7. badbob
    badbob
    Yep,guess I did not explain it well,I have used my kitchen oven,and at the snowmobile shop we had an old kitchen oven we used,but ventilation is a must,the fumes are toxic.
    Lousyweather and don2222 like this.
  8. DexterDay
    Classic Bay 1200!! Love that stove!!
    I use dry moly but clean mine every 2 years (only 1-2 ton pushed through each of my two pellet units) . I would rather remove and clean myself
  9. don2222
    don2222
    Salem NH
    Hi Dexter
    I found a very deserving home for the CB1200 I refurbished but I miss it already. :-(
  10. badbob
    badbob
    Well don,should have started new post,but let me know if you coat an impeller and check it later,even if it is a year later.Bob
  11. imacman
    imacman
    Denver, NC
    Never knew they made Hi Temp powder coat. The ceramic I think is cool......not so sure about the powder.
  12. badbob
    badbob
    Yep cool stuff,I am not up to date on new stuff.Used to coat pistons and bake them in the oven,then when running,material transfer would occur to the cylinder walls.Now when you buy replacement/overbore pistons,they come coated.But now really hi temp stuff is now cheap,the ceracoat and other gun coat stuff,I need to get some and try it.
