Friend called me and asked if I wanted some
Discussion in 'The Wood Pile' started by NYCountry, Oct 25, 2016.
  1. NYCountry
    NYCountry
    Mohegan Lake NY
    I sure do , brought my splitter there and split some . Not sure what it is , looks yellow and little stringy when splitting
    schlot, unclefess, Unicorn1 and 10 others like this.
  2. Jeffrey Svoboda
    Jeffrey Svoboda
    Nice. :thumbs: Looks like black locust to me.
    J. Dirt, Unicorn1, Hammy and 3 others like this.
  3. Ashwatcher
    Ashwatcher
    West By God Viginia
    Kinda looks like locust to me---if so, the Holy Grail of BTU's
  4. NYCountry
    NYCountry
    Mohegan Lake NY
    1 year to dry , I should of checked with the meter to see mc
  5. Jeffrey Svoboda
    Jeffrey Svoboda
    Yes you should have. This will be my first year burning locust. Mine was standing dead and css early this spring.
    Hammy, Ashwatcher, Horkn and 2 others like this.
  6. NYCountry
    NYCountry
    Mohegan Lake NY
    Just checked the mc one said 22 and the other smaller split read 17
  7. NYCountry
    NYCountry
    Mohegan Lake NY
    One said 22 and the smaller one read 17 they were there since last year sitting on concrete
    Hammy and Backwoods Savage like this.
  8. Jeffrey Svoboda
    Jeffrey Svoboda
    Nice!! :yes: Would think that should burn just fine this winter. Save it for the really cold nights.
  9. Backwoods Savage
    Did you re-split the wood so you could get a fresh reading? Nice stack of wood there no matter what it is.
    Hammy, Ashwatcher and Horkn like this.
  10. NYCountry
    NYCountry
    Mohegan Lake NY
    No I didn't , so that's the way you get a more accurate reading
  11. Backwoods Savage
    Yes, if you must use a MM, it does no good to just take a reading from an old split or even one that has been split for several hours. It needs to be freshly split and checked in the center of that split to be most accurate. This is part of what I mean when I say there are too many variables and even theories when it comes to using a MM. Still time is the best way to make sure wood is right. Experience will come in very handy too for knowing when it is best. Hang in there, it will come.
    Hammy, Ashwatcher and NYCountry like this.
  12. Locust Post
    Did I hear somebody say Locust......Oh yea, nice pile of BTUs
  13. Horkn
    Like any tool, there are proper ways to use them. Get a fresh split and retest. The MM is a simple tool to use. If you use it the right way. :)
    That said, it looks like black locust to me as well. It's really good wood.
    Hammy, Jeffrey Svoboda and Ashwatcher like this.
  14. Ashwatcher
    Ashwatcher
    West By God Viginia
    Jeffrey Svoboda You are in for a treat, but only when its cold-COLD! I swear its almost too hot for me to burn-I can have a fire going, say ash and beech and throw a couple splits of locust on and in 20 min the temp spikes 3-5 degrees! It has run me to the crank out windows more than once...nice prob to have I guess-Good job NYCountry :yes:
  15. TurboDiesel
    Looks like locust to me. Nice score!
    You've got a good friend there for sure!
  16. bogydave
    Black locust .
    Prime time score !!!
    Serious BTUs :yes:
    J. Dirt, NYCountry and Hammy like this.
  17. Eric VW
    Agreed on all points-
    But allow me to add this:
    I resplit (well, my wife did) some cherry yesterday, and when I stuck the middle of the fresh face, split and stacked from last August, the middle was sub 20%, but nearer the sap wood (and bark, which had been errantly laid down facing instead of upward to shed rain) the reading was in the hi 20's.....
    So I find it best to hit more than one spot with the prongs (deeply impressed Ashwatcher ), but hopefully not my finger!
    Backwoods Savage and Hammy like this.
  18. Ashwatcher
    Ashwatcher
    West By God Viginia
    Understood Eric VW but listen to me and hear me now...I'm not an innovator or a rocket scientist (not even a stove/rocket scientist) but I can assure you the key that has been discovered is the distance off the ground once C/S/S---I can show you proof, and my MM is true, that I have 18 mo old oak of any variety you choose that is between 3.5 & 7% moisture right now---Face it south-no shade-ensure it receives a min of 12 hrs a day direct sun and if possible place it cross to the prevailing winds and I guarantee it...a minimum of 8" of the ground, you will be amazed by the results). I'm not burning it because I have that luxury but it can and is being done...
