Clutch for the GF's 4Runner
Discussion in 'The DIY Room' started by foragefarmer, Oct 24, 2016.
  1. foragefarmer
    foragefarmer
    Central, Virginia
    It sucked to do but got done.
    The cause of the problem.
    I think the flex plate was made in China as well. The GF bought the 4Runner used with no history. The engine is not original so I guess they threw in a clutch while they were at it.
    The new clutch kit I put in was made in Korea.
  2. bassJAM
    bassJAM
    Cincinnati, OH
    That's crazy, I've put in 5 clutches over the years and have never seen a pressure plate fail! I almost always use OEM parts or upgraded aftermarket parts, it's a crappy job that sometimes lasts more than a day so I do everything I can to prevent having to do it again.
  3. brenndatomu
    I've never seen that one before either
  4. concretegrazer
    concretegrazer
    Southwest MO
    2 out of the last 3 I've had to replace were due to broken pressure plates.
  5. foragefarmer
    foragefarmer
    Central, Virginia
    CG, that officially sucks. I wish you better luck with the new ones.
    concretegrazer likes this.
  6. Jeffrey Svoboda
    Jeffrey Svoboda
    Are those grooves on the pressure plate fingers from the throw out bearing? It's hard to tell how bad it is in the picture. Does she ride the clutch pedal or not take it out of gear at a stop light?
  7. gmule
    gmule
    Conifer Colorado
    I am a professional auto mechanic and see that quite often on failed clutches. Along with bad throwout bearings and shredded cutch disks. I pulled this one out of a Toyota Rav 4. It drove in and was really noisy as you can imagine but it still moved under its own power. Your guess is as good as mine as to how it happened.
