stuck piston rings.....what's the secret?
Discussion in 'Chainsaws and Power Equipment' started by Scotty Overkill, Oct 20, 2016.
  1. Scotty Overkill
    OK guys, before I go and do something rash and stupid, do any,of you have a formula or method for getting piston rings un-stuck? I have this ultra-rare Mac BP-1 here, and I had one HECK of a time getting the piston freed from the cylinder. I finally got it out and got the cylinder honed, but now l'm having problems with the rings. I don't wanna damage the lands, and the rings are stuck with a combo of rust and carbon. Any secrets? Believe me, I'd like to be able to just replace the piston but unless any of you have a cross reference to one I can use, you can't just go to the local Mac store and pick up a piston for this saw....
    I bought a set of NOS rings, but I gotta reuse my piston...
    After a several day soak in ATF/PB Blaster/diesel concoction and over 200 blows with my 10lb slide hammer and custom-made pulling apparatus made from a old pair of vise grips and some saw blade material, it came out. The cylinder is iron-sleeved and in excellent condition, but the rings need replaced....
    After I cleaned the Pistons up a bit. Now once I get the rings out, I'll be off to the races!
  2. Grizzly Adam
    Grizzly Adam Guest
    Is that an old craftsman c3 drill with one of the new lithium ion batteries?
    NortheastAl likes this.
  3. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    :dex:
    Did you try Kroil? It's expensive, but the best penetrating oil I have used. It is used by the industrial guys on large 1-3 inch bolts on power projects to loosen them up after sitting for years. They were also installed with a hytorq, and have some meat, but they always come loose. I used it last winter on my 3 or snowblower to loosen some salt rusted bolts, and it worked. Good luck :dex:
  4. Scotty Overkill
    The drill and battery are around 4 years old
    clemsonfor and NortheastAl like this.
  5. Scotty Overkill
    I'm going to buy a can of that Kroil, trying to find it locally.
  6. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Amazon, its not something you will find locally unless you have a solid industrial supply center
  7. Grizzly Adam
    Grizzly Adam Guest
    I havebasically the same setup but the drill is probably a dozen years old with batteries a couple years old.
  8. Scotty Overkill
    We have a Grainger here, I'll check there first. See the problem with something like these stuck rings is that it's VERY hard to initiate motion, and for stuff like penetrating oil to work, you need to have some way to initiate motion. Very hard to do without screwing up the piston ring lands (grooves). And for the most part, this piston is irreplaceble.
  9. OhioStihl
    OhioStihl
    Southern Ohio
    Electrolysis?
  10. Kevin in Ohio
    Kevin in Ohio
    In the past, when I have had them stuck, I've had good luck with heating and cooling. Mainly when the piston is aluminum with steel rings. Thermal expansion rates are different so sometimes it is enough to free them up. On stuck bolts the candle wax trick has worked pretty well for me as well because of the same thing.
  11. Warped5
    Warped5
    Northwest IN
    So, given that the piston cannot be replaced ..... I'm thinking heating it up with a hair dryer/paint stripper .... let it get to room temp and putting in freezer for an hour .... ??
    Gentle heat/cooling ....
    NortheastAl, Horkn and Woodsnwoods like this.
  12. Bret Hart
    Bret Hart
    Central NY
  13. Kevin in Ohio
    Kevin in Ohio
    I don't think a hair dryer would get it hot enough. I've got an old oven in my shop that I got to do powder coating. Set the parts on a metal tray and bake them, then let cool slowly as you say.
  14. hdtoolmkr765
    hdtoolmkr765
    Kokomo, IN
  15. Scotty Overkill
    Electrolysis is a NO-NO with aluminum, magnesium and pot metal......I was all ready to try it and did some research. This is an aluminum piston with iron rings.
    I read a good thread in a tractor forum that said about using the heat-cool method and, being the rings are sticking out a little from the piston, gently tapping the circumference of the piston ring with a brass hammer, I may try my plastic deadblow hammer or even make a mallet out of a chunk of hickory.
    So I'll get some Kroil, heat and cool it a few times with the propane torch and tap on the ring some. Worst case scenario is I mess up the lands, if I do that maybe I'll look into having them opened up a bit on the lathe and getting slightly thicker rings.
    NortheastAl, Horkn and eatonpcat like this.
  16. cre73
    cre73
    Central Il
    That is one cool saw. Had to do some google-foo after seeing the two pistons in your hand. Thought you were messing with us or maybe smoked a little to much wacky weed. :loco: :crazy:
  17. hdtoolmkr765
    hdtoolmkr765
    Kokomo, IN
    I've never had to use anything other than Kroil, no heating and cooling, no tapping or anything. I just soak them in Kroil, the next day just pull them off. Done it probably a dozen times. Never had it not work.
  18. bobdog2o02
    bobdog2o02
    Drury Lane, PA
  19. bocefus78
    bocefus78
    Yep....and simple green diluted with water is a cheap and easy solution for those ultrasonic cleaners. Crappy description on that one IMO, but some of those machines even heat the solution for you. Heck, maybe all of them do. I dunno?
    NortheastAl and Horkn like this.
  20. Warped5
    Warped5
    Northwest IN
    I got the large one at HF.
    Used to 20% coupon I get in the mail every week ..
    clemsonfor, NortheastAl and Horkn like this.
