Pacific energy thoughts?
Discussion in 'Modern EPA Stoves and Fireplaces' started by Well Seasoned, Oct 14, 2016.
  1. Well Seasoned
    Who has or knows of the Pacific energy woodstoves that can give me your thoughts on them? I may luck one up.......Thanks! :)
    Horkn likes this.
  2. oldspark
    oldspark
    NW Iowa
    Best stove ever, want to buy one?:whistle:
    savemoney, papadave, jeff_t and 3 others like this.
  3. Well Seasoned
    You have a thread about it, I recall. Ill need to go back and review it.
    I may be coming down to 2 choices...... either a pacific energy or a vermomt castings. Both new, good deals.
    savemoney, Woody Stover and Horkn like this.
  4. concretegrazer
    concretegrazer
    Southwest MO
    Haven't seen much out there on V.C. since the last buy out. I'd still be concerned about the longevity of them. So I'd probably go with the P.E. between the two.
  5. mike bayerl
    mike bayerl
    I like my PE T5 very much, but I've only run it one season and have no experience with VC.
    savemoney and Well Seasoned like this.
  6. bocefus78
    bocefus78
    I have a pe Vista insert and for its small size, it cranks out the heat.
    Im on year 6, and my ss baffle warped, but allegedly it's lifetime warranty. I'm currently awaiting a reply from my pe rep in response to the pics I sent. So ill.be able to tell you how they handle customer issues shortly.
    PE baffle warped! | Firewood Hoarders Club
  7. Oldhippie
    Oldhippie
    Ashby Ma
    The PE stoves have a very good reputation. The Alderlea stoves are gorgeous, and they are great heaters.
    savemoney, papadave and Well Seasoned like this.
  8. Locust Post
    I know Certified106 has a PE and believe he always has good to say and he seems to get some nice long burns.
  9. mike bayerl
    mike bayerl
    What PE are you looking at? Specifically, Alderlea vs. Traditional? The fire boxes are the same , but the cast iron jacket changes it from a radiative heater to more of a convective heater.
  10. oldspark
    oldspark
    NW Iowa
    The bottom line for me is you dont have to spend that much money for a good stove.
    My PE did not work and I couldn't get any satisfaction from PE so I had to eat the stove.
    My Drolet works like it supposed to, the PE did not.
  11. Well Seasoned
    Good info here, I'll probably be going with the Alderlea T5.......
  12. raybonz
    raybonz Moderator
    Carver, Mass.
    So far so good with my T-5.. I did have an issue where the stove pipe would get too hot and adding some course steel wool to the air tube under the front air intake angle iron made a big difference..
    savemoney, milleo, Loon and 2 others like this.
  13. Oldhippie
    Oldhippie
    Ashby Ma
    Vermont Castings was a wonderful brand name in 1976 to about 1985, when they made these stately old school cast iron stoves. But the brand has changed hands and deteriorated over time. Their EPA stoves have a reputation of very high maintenance and associated costs for rebuilds.
    Well seasoned, are you buying new? Talk to raybonz he's got one.
  14. jeff_t
    jeff_t
    SE MI
    The Super27/T5 stoves are capable of some crazy long burns for a 2ish cu ft firebox. Pretty easy to control, too. I have tried to let mine get away before, and it always calms down as soon as I shut the air down. A secondary air control linked to the primary makes this happen. I think you'll be tickled after the little Jotul.
    They do breathe easy. I have around 13' of pipe, and I will consider adding a key damper if I ever have to take it apart and clean it.
    The 27 has side shields built onto the stove. The only place there is any more radiant heat is off the top.
  15. raybonz
    raybonz Moderator
    Carver, Mass.
    Plenty of heat for cooking too.. Stove is running as I type this.. I also have the blower which does a good job getting the heat out when the weather is cold..
    savemoney, milleo and Well Seasoned like this.
  16. Well Seasoned
    Sounds good. I was wondering how the overnight burns were. Advertised as 8hr max, but I suspect with all that fire brick, A fine bed of coals would be present after an overnight. Can anyone attest to the quality of the enamel? Also, The little ash door opening "seems" in my mind a little small and cumbersome. So you guys use it alot?
    Loon and savemoney like this.
  17. raybonz
    raybonz Moderator
    Carver, Mass.
    I never use the ash door.. Easy to just use shovel.. The bricks are soft pumice and break easy which is a problem in on the back wall where the logs hit when loading.. I replaced those with the heavy ceramic bricks I bought at TSC and they worked fine and won't break.. Rest of the pumice bricks are still in service.. I can't speak to the enamel as my T-5 is painted.. Oh and yes the burn times are very good with overnight burns easy to attain at least with hardwood.. NS loading is good so no logs rolling out problems.. I believe EW is ~15.5" and 18" NS
    savemoney and Loon like this.
  18. jeff_t
    jeff_t
    SE MI
    The ash dump is useless. Just shovel it.
    Six to eight hours at WFO is about right, but lower burns can go 10-12 easy.
  19. Oldhippie
    Oldhippie
    Ashby Ma
    How many square feet are you heating? If I lived where you lived I'd be thinking go big at least as big as I could. It gets cold up there. I know I don't need to tell you that :) and the nights are long. With my old VC Resolute, if I got up at the crack of dawn and rushed to fill the stove before coffee (heaven forbid) I might be able to stoke it off the hot coals, but meanwhile the room would be cold.
    Realize you may be constrained by room size, clearances etc..
    I am really appreciating the 2.5cu ft of that Absolute Steel. My Fireview will give me overnight burns too, with a smaller box, but it's outside dimensions aren't much different than the Fireview and the AS has the option of rear or top exit flue and right or left loading door.
  20. raybonz
    raybonz Moderator
    Carver, Mass.
    Next weekend WS is having an open house\pig roast.. They give good deals as well.. You should checvk them out Well Seasoned
    savemoney, Chvymn99 and Well Seasoned like this.
