It's time to change the batteries
Discussion in 'Everything Else (off topic)' started by TurboDiesel, Oct 14, 2016.
  1. TurboDiesel
    the batteries in the smoke detectors.
    I think we need to change the batteries in the smoke and co2 detectors when we light the stoves rather than wait till daylight savings time.
    Happy heating season to all.
    Safety first.
    will711, will donati, Thor and 6 others like this.
  2. wildwest
    thanks for the lifesaving reminder. :emb: I may or may have not removed the CO detector because the battery was low and it was beeping yesterday. Must get new 9v batteries tomorrow......
  3. Eric VW
    The smoke detector closest to our bedroom started chirping last weekend. Freshened up the battery, no more chirping.
    Done.
    Great reminder TD.
  4. bogieb
    Great reminder! I got two new detectors last year and they are supposed to last 10 years on the batteries. I still need to do a check of them, just to make sure - so I will put that on my to-do list for this weekend.
  5. rottiman
    Take the time to check the dates on them also. Anything 10 years or older should be replaced as well.
    Backwoods Savage and bogieb like this.
  6. will donati
    will donati
    Ontario
    CO is produced whenever fuel is burned and indoors it just build up to toxic levels when our appliances malfunction. We often forget changing batteries promptly. One has to be very alert in ensuring that your home security monitoring systems are working fine One good solution I would suggest is changing them when you set the clocks back in the fall and ahead in spring.
    TurboDiesel likes this.
  7. TurboDiesel
    Welcome to the club , will!:handshake:
    will711 likes this.
