Sierra Hearthstove Classic Turbo-Burn Model 2000T
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by Woodier, Oct 13, 2016.
  1. Woodier
    Woodier
    Plunkett
    I am looking for clearance and installation specs for the above stove. It looks like this. There is no info on the stove. I already emailed Sierra in CA and was told they were made in Virginia by original company. Thanks, Woodier[​IMG]
    WeldrDave, Thor, fox9988 and 2 others like this.
  2. papadave
    fox9988 and Scotty Overkill like this.
  3. papadave
    Scotty Overkill likes this.
  4. Scotty Overkill
    Welcome to the club,Woodier! Have you done a comprehensive Google search yet? Usually the manuals can be found via .PDF files on the 'net. That should give you all the clearance/install guidelines.
  5. Scotty Overkill
  6. Scotty Overkill
    Call this #, maybe they can help you out...
    papadave likes this.
  7. papadave
  8. Scotty Overkill
    I know. I looked and looked and looked. Wierd.
  9. Woodier
    Woodier
    Plunkett
    Thanks for the warm welcome and for trying to answer my question. There is no tag on stove anywhere. If I can find one on a clone that would do me if it shows clearance specs. WOODIER
  10. papadave
    "I know. I looked and looked and looked. Wierd."
    Same here. Not much luck.
    Reminds me of when I first tried finding info on my old Ashley. Made a couple phone calls, sent e-mails, did a bunch of Googling.......nuthin.
  11. papadave
    Well, if you look at Unicorn1's link I posted, one of the pics shows CTCs of 36" sides and back on his model 2000. Looks similar to your stove.
    36" is the default when there's no info, and it's an old stove if I'm not mistaken. You could build an air-gapped wall shield to reduce that.
  12. Smokinpiney
    Smokinpiney
    "South" Jersey
    That's an awesome lookin stove! I love the side load with the front glass. Plus it's called a "turbo burn"! :thumbs:
    Sorry I can't be of any help with the manual. Hopefully one of the guys here might know something
  13. TurboDiesel
    Welcome to the club, Woodier.:handshake:
    Thats a great looking stove. Good luck with your search. And dont forget the finished install pics. :ithappened:
    and saw pics
    and splitter pics
    and pics of firewood stacks
    and ....;)
    :picard:
  14. brenndatomu
    My inlaws had one of those in their last house...made some heat for sure, but a hungry lil beast she was. They had no manual either...about the only place I came up with any info at all was over on that "other" site. If you google around it comes up.
    I tried to get them to replace that stove with a newer one but no dice...then I gave it up because they weren't using real dry wood anyways...figured an "EPA" style stove would just cause 'em headaches.
    Looks like they will be installing a Englander NC30 in their new house...we'll see how that goes...I think I'll give them some good dry stuff to start off with, don't want a bad first impression.
  15. WeldrDave
    brenndatomu and fox9988 like this.
  16. Woodier
    Woodier
    Plunkett
    Sorry, been there, tried that....even contacted Sierra. They said this stove was made in Virginia before they bought the company as you can see this model is not listed. Think my only hope is having someone reply that has a tag on the rear.....but i am beginning to doubt that they ever applied that......thanks for trying everyone.
    WeldrDave likes this.
  17. WeldrDave
    Dam, Sorry!
  18. Coaly
    Coaly
    NE PA
    Not sure why there is a clearance question Woodier.
    No tag means unlisted. Period.
    NFPA 211 Standard has a section for unlisted stoves. Your clearance is 36 inches to combustible or reduced to a minimum of 12 inches with approved shield. The tags Sierra Mfg. Inc. used were not UL tags (before UL logo use) but were marked 36 inches tested to UL 1482. Common for stoves without shields to not gain a reduced clearance when tested.
    Sierra Manufacturing of Virginia Inc. made the Hearthstove, Imperial, Supreme, and Crossfire.
    Invented in 1979 and patented 1981 by John Christophel, Harrisonburg VA.
  19. Woodier
    Woodier
    Plunkett
    Thanks Coaly for your information. The problem is I live in Canada where, as you know everything is a lot cooler up here. This makes for slower tree growth and denser wood that burns hotter and to add to that, higher O2 levels at -45 temperatures makes the denser wood burn even hotter (as long as you are not too high up the mountain). Hence our clearance for unlisted stoves is 48 inches.....BUT WE ONLY HAVE TO USE HALF THE AMOUNT OF WOOD. Its a lot like coal and I am sure you can understand the concept Coaly!
    Our insurance people don't like unlisted appliances. Thanks again for trying to help me out. Too bad you couldn't capture all that political heat that's out there right now! Hope things work out for you guys!
  20. Coaly
    Coaly
    NE PA
    Didn't know you were in Canada, 48 inches for untested. Sorry. There's a Plunkett near me in Pennsylvania! Your Territory will give specifics for reduced clearances. You're also into a WETT Cert. More info here;
    http://www.saunafin.com/pdf/woodburning/wood-heater-residential-uncertified.pdf
    Basics here;
    http://www.ccme.ca/files/Resources/air/wood_burning/pn_1479_wood_burning_code_eng.pdf
    Saskatchewan pg. 17.
    Pipes;
    A non-commercial service in support of responsible home heating with wood - Installation Rules For Flue Pipes
    Ha! That girl is cold as ice. :picard:
