Saw Adjustments
Discussion in 'Chainsaws and Power Equipment' started by MightyWhitey, Oct 12, 2016.
  1. MightyWhitey
    MightyWhitey
    Is it common to have to "tweak" your saws Carb settings based on humidity, temperature, of air pressure??? Seems I have to do this a fair bit.
  2. papadave
    Bought mine in '07 and haven't touched the screws once.
    Maybe I should, but I'd just make it run bad.
    Runs fine, so I'm leavin' it alone.
  3. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    It isn't uncommon to tweak certain saws depending on those conditions. Some of mine are a bit finicky and need slight adjustments, but others dont seem to need it as much.
    While cutting, I always listen to the tune. If it sounds off, then it gets adjusted.
    Hammy, cnice_37, thistle and 2 others like this.
  4. TurboDiesel
    X2
    My 029 is about 15 years old and as far as I know it has never been adjusted.
    Runs fine.
    Hammy, Eric VW and papadave like this.
  5. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    What kind of saw is it? Just curious. Also, do you cut at massively different elevations? I never touch the adjustments unless it is new out of the box and I adjust the dealer settings (sometimes). Seems like an odd problem to me.
  6. MightyWhitey
    MightyWhitey
    It's a late '70's ProMac 610. Seems like I'm having to adjust the idle speed in different temperatures.
    Hammy likes this.
  7. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I think my father has that same saw. I never got into it too deeply, but it does not run consistently, and never has. Once the thing is warm, it does not start well, and will not run well once it starts. Hate that thing.
  8. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    I have my saws set right on the edge of 4 stroking and only have to adjust with elevation changes from home to camp. A 2000ft change will run a tad rich, nothing significant maybe a 1/16 of a turn. I don't know how long it's bee since a carb rebuild. Maybe the diaphragm is starting to stiffen up. I think those run the walbro hdb carbs. The aftermarket k10 rebuild kits can be found for around 5 bucks.
  9. Scotty Overkill
    Whitey, it may just need a carb overhaul.........
    Some saws can be finicky. I've had several Pro Mac 605s and 610s over the years, and for the most part they were pretty reliable saws. The worst thing about them IMHO was the cheesy vacuum oiler....unreliable at best, in my experiences....
    Hammy, thistle, MightyWhitey and 2 others like this.
  10. Scotty Overkill
    Different octane fuels and inconsistent oil mixtures can also result in inconsistent tune as well. Something good to keep in mind.
    When I run aviation fuel in my saws, I've got to re-tune them.....
  11. Scotty Overkill
    And one other thing could be the culprit.....the crank seals may be going bad. The saw may run good cold, once it warms up, the seals may get a little "loose" and let air in, resulting in a lean situation which will make the idle speed run up.
    One way to test this is once the saw is warm, spray some ether around the crank seals when the saw is running. If the saw jumps up in RPM, there's your sign!
    Hammy, thistle, MightyWhitey and 3 others like this.
  12. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Time to upgrade to a Stihl ? :dex:
  13. Duane(Pa)
    Duane(Pa)
    Centre Co.
    Cold air has more oxygen and will make an engine run lean. I adjust my saws to run right in cool/cold weather. They may end up a little rich in summer conditions, but I do very little serious cutting in temps above 60/70 degrees. Fat saws far outlive lean saws!!
    Hammy, thistle, Chvymn99 and 4 others like this.
  14. Scotty Overkill
    I absolutely concur!!
    I keep all my saws a tad fat, especially if I'm working them hard......
    Hammy, Duane(Pa), thistle and 2 others like this.
  15. Mag Craft
    All those things can affect the carb settings on these saws. So to answer your question I would say yes that it is no big deal if you have to adjust the carb when ever you cut. I never go cutting without some adjusting tools for the carb because I know that those things will affect the tuning.
    Now I will say that maybe I am a little more particular than the next person and some saws are more sensitive than others but it is no big deal to me to have to tune the saw for optimal performance.
  16. Scotty Overkill
    Exactly! I have MANY tuning screwdrivers, always have one with me when I'm cutting. It pays to learn how to tune a saw if you're a serious woodcutter....
    Heck, even checking your saws air filter periodically when cutting will help your saw stay tuned better.....
    Hammy, CTYank, thistle and 4 others like this.
  17. MightyWhitey
    MightyWhitey
    Exact opposite here..........................starts easily warm or cold...................ran her out of fuel once.................has never happened again. Starts warm or cold for me.................but I know how to start her in those situations. Love this saw.
    Hammy, thistle and Woodsnwoods like this.
  18. MightyWhitey
    MightyWhitey
    Very well could be possible. I know Dad never did it; and neither have I since it's been my saw for 20+ years now. Will look into for sure.
    I've opened up the oiler on this saw, and it does seem to oil. I do have another NIB oiler on hand though.
    Hammy, CTYank, thistle and 2 others like this.
  19. MightyWhitey
    MightyWhitey
    With the big EAB ash loads I've been processing; it's been in the 60's-70's outside, and I've been having to cut much of this wood to length for it to fit into my stove before I split it. I usually role out about 6 or so rounds measure and cut each to length. The rounds being anywhere from 8" to almost 24" in diameter. Don't get me wrong here..................saw is doing great work cutting..............just that when it gets warm, the idle speed DROPS almost to the point of stalling. So I just turn the proper screw a bit to get it to idle a bit more gooder.
    Hammy and Woodsnwoods like this.
  20. Scotty Overkill
    Might need leaned down on the "L" screw. If you do that you'll have to turn the idle back.....
