Wood ID
Discussion in 'The Wood Pile' started by HDRock, Oct 9, 2016.
  1. HDRock
    Trailer has mixed wood in it and these are the only pictures I have so far.
    Most of what is in there I think it's the same and I'm thinking Elm or possibly Box Elder, could be something else too.
    Creamy color inside, some have brown streaks down the middle some in with a little tiny bit of red streak.
    I have a bunch with no bark and it is Bumpy, only Bark pictures I have right now are the ones in the trailer
  2. papadave
    Um, didya fergit sumpthin there HD?
  3. HDRock
    Yep for a hot minute.
    Speedy Gonzales Dave:D
  4. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Looks like elm, sounds like some box elder. Btu's :dex:
  5. HDRock
    Trailer is pretty much full of BTU'S, stacked in pretty good, just the top is helter skelter
  6. MightyWhitey
    MightyWhitey
    Box Elder will likely be gnarly and twisted when split. And will likely have reddish streaks down thru the wood when split.
    Hard to tell from the pix due to the age of the wood.
  7. Matthewchopswood
    Matthewchopswood
    Shenandoah Valley, VA
    First picture resembles tree-0f-heaven.
  8. HDRock
    Burns good, just lit some up.
    This stuff is mostly 4 to 8 inches and two and a half years stacked.
    When I look close I'm thinking More so Elm, it has crossed grain flecks like Maple but smaller and it's a light creamy color, it's not gnarly
  9. Chvymn99
    The Red tells me Box Elder... it's also related to the maple family...
  10. Backwoods Savage
    It does like like both elm and box elder.
    Horkn, NH mountain man and HDRock like this.
  11. MightyWhitey
    MightyWhitey
    The red streaks do look like box elder; but, box elder rarely has such straight grain in it like your pix show. Just saying of course.
  12. g60gti
    g60gti
    NY West
    Doesn't look like any elm I've ever split, not stringy enough. Box elder or red maple, just my .02.
  13. Matthewchopswood
    Matthewchopswood
    I found the following images. I burn the stuff because it is on our property. If kept off the ground and seasoned properly it burns alright. I can't see it go in a burn pile after I take the time to cut them down. I typically mix with some oak and it does the trick. image.jpeg image.jpeg
    Horkn and HDRock like this.
  14. NH mountain man
    NH mountain man
    WMNF N.H.
    I agree, as someone who c/s/s and burns a lot of Elm, if it isn't all stringy, it ain't Elm. Elm never, ever, splits straight and clean. Unless it is so rotten it breaks apart punky like.
  15. MightyWhitey
    MightyWhitey
    Red/slippery elm splits easily when fresh cut.
    NH mountain man, Horkn and HDRock like this.
  16. HDRock
    I split up a bunch of this wood today, I did find a piece of elm in there but, most of it is some kind of maple, as far as boxelder I'm not sure because most of it does not have any red in it.
    The elm
  17. Horkn
    Ah, there's the string cheese elm!
    But yeah, looks like a lot of box elder.
    I burn the box elder too. If I cut it, I'll split and stack it. It's all btu's.
    NH mountain man, Thor and HDRock like this.
  18. HDRock
    Yeah, I'll burn it when it's not too cold then mix it with, Ash, Hickory, Oak, whatever.
    10in rounds are 16% mc
    NH mountain man, Thor and Horkn like this.
  19. Fanatical1
    Fanatical1
    Looks just like boxelder to me. Most boxelder does not have the red streaks in it, that's just a special bonus for the wood workers! And boxelder is part of the maple family.... Easily confused with red maple and often sold as maple.
  20. HDRock
    It must be boxelder then, I only had a little bit of box elder before and it had a lot of red in it.
    I burned a lot of Red Maple and it's heavier than this
