New use for your splits
Discussion in 'The Wood Pile' started by Timberlake0377, Oct 6, 2016.
  1. Timberlake0377
    Timberlake0377
    North Carolina
    I don't post much but I ran across this advertisement today and thought I had to share with you all. Might not be the right forum, but I thought you would all enjoy it! If anyone has some old lamps laying around and some "reclaimed" (i.e. seasoned?) splits, you could sell them for a small fortune! Just remember to try different splitting techniques to enhance the cross sections... :thumbs:
    Split Grain - Reclaimed Wood Lighting - Touch of Modern
  2. Chris F
    Chris F
    Micksburg, Ontario
    Different, that's for sure.
  3. dylskee
    dylskee
    Central MA
    A little pricey for a split and some aluminum, but to each is own..... :thumbs:
  4. Timberlake0377
    Timberlake0377
    North Carolina
    Call it art and slap a few hundred bucks on it, someone will bite!
    Hammy, savemoney, Chopy and 4 others like this.
  5. dylskee
    dylskee
    Central MA
    Hahaha, you're absolutely right! :rofl: :lol:
    Hammy, savemoney, Chopy and 3 others like this.
  6. NortheastAl
    NortheastAl
    Putnam County NY
    Gonna buy a bandsaw and some electrical components. Figure if I sell all my splits made up like lights it'll be better 'n' hittin' the lottery.
    Are they for real with these prices?:loco: :crazy:
  7. Horkn
    I am trying to figure out how to replicate these. So, a chainsaw, cut a boatload of slots, and somehow run a light into it?
    I'm serious.
    Viking80, Hammy, bassJAM and 3 others like this.
  8. Timberlake0377
    Timberlake0377
    North Carolina
    my guess is slice it up evenly with something like a bandsaw or table saw with a sliding jig for the cleaner cut. Actually first you'd probably want to bore it out somehow to house the wire and light fixture. Then it looks like the individual slices are somehow evenly separated, maybe with some kind of spacers. I'm thinking even stainless nuts would work. With those you could secure each one with screws for a super secure fit. Extra care to make sure all the grain lines up and it's perfectly straight is probably key in making it look good. Then just figure out a way to get a standard lamp fixture in there and wire it up. Bam, a $300 lamp!
    Viking80, Hammy, schlot and 5 others like this.
  9. Timberlake0377
    Timberlake0377
    North Carolina
  10. Horkn
    That was what I was thinking. I would use LEDs, but the radial arm saw for smooth clean even cuts with a jig of some sort. Drill the other end with a spade bit of some sort for the lightning. Then make a metal stand.
  11. HDRock
    I'm not sure how they space them out but probably bored out the center on a lathe or a drill press jig, plastic or glass tube in the center.
  12. Timberlake0377
    Timberlake0377
    North Carolina
    You could even just snake in a short strand of LED rope lights if you wanted to go that route. Less heat and you wouldn't have to worry about a shroud for an incandecent bulb that might be a fire hazard. This is making me want to consider adding to my winter project list. Or maybe a Christmas gift idea for those who have everything!
    Hammy, Backwoods Savage and Horkn like this.
  13. Horkn
    I think a nice split of cherry, or shagbark hickory would be really good for this.
    If I do it, I'll make a couple. Setting the saw up would be 75% of the work.
    This may be a Christmas gift or two. :)
  14. HDRock
    2 1/2 or 3"
    Buy 2-1/2" Forstner Bit at Woodcraft.com
    Hammy, Shawn Curry, Chopy and 2 others like this.
  15. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    If it was me, I think i would make the slices first. Then stack a few, and drill a pilot down the middle. Scribe a circular hole larger than the light bulb and socket on each cookie and cut out with a scroll saw. Cutting a split with the center bored out is dicey unless you use a bandsaw.
    Trying to put a hole down through the end grain of a piece of wood with a Forster bit can be very hard and dangerous too.
    Once the hole is cut, drill a small hole on either side for the rod. I'd use brass or better yet a steel rod with brass tube spacers the next diameter up.
    I'd like to see someone make one, it looks like a fun project. I'd be curious if a regular bulb would cause warping and cracking of the slices.
  16. HDRock
    Rip the split down the middle , hollow the two halfs to what ya need on router table, glue em back together, make your cross cuts.
    Probably need a jig to hold the split for ripping cuz it's not straight n flat
    Hammy and Backwoods Savage like this.
  17. Eric VW
    Very neat......:)
    Hammy and schlot like this.
  18. schlot
    schlot
    NW Iowa
    Wonder what kind of btuh we could get out of one lamp? :)
  19. Minnesota Marty
    Minnesota Marty
    Eastern Minnesota
    Timberlake0377,
    Eclectic !!! I love it.
    Thanks for posting it.
    Another neat one would be some river birch with the bark on in that fashion.
  20. Oldman47
    Oldman47
    Illinois
    Forget an incandescent bulb. The heat build-up would be unsafe. These days they make LEDs in all sorts of sizes and shapes and run far cooler than an equal amount of light that is the result of a hot wire. They also last a very long time. Vintage LED Filament Bulbs | 1000Bulbs.com
    Viking80, Horkn and Backwoods Savage like this.
