BTU calculator
Discussion in 'The Wood Pile' started by Woodsnwoods, Sep 28, 2016.
  1. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I spent a few minutes last night putting together a calculator which can show you a few things. It will show you how many BTU's you burn, using individual species as the input. It then shows that assuming a certain efficiency, you would have burned x gallons of oil or propane, and have saved yourself x dollars in avoided costs from not burning oil or propane. You can also add your local oil and propane costs. Admittedly there are some assumptions, but I wanted this for myself and feel once dialed in it should be shared with the group. I have reached out the admins to understand how to add as a resource, in hopes to share a draft with the group soon.
  2. Grizzly Adam
    Grizzly Adam Guest
    Looking forward to seeing this.
  3. milleo
    milleo
    Grizz I thought you already had one posted...
  4. My IS heats my home
    My IS heats my home
    Albany, NH
    yeah, I think Grizz did one last winter
  5. saskwoodburner
    saskwoodburner
    x 2
    NortheastAl and Sean like this.
  6. Grizzly Adam
    Grizzly Adam Guest
    Read his description, this is a different kind of calculator. We have two different kinds so far.
  7. milleo
    milleo
    :popcorn: I'm getting my popcorn first before we run out...:)
  8. bushpilot
    bushpilot
    Eastern Washington
  9. Grizzly Adam
    Grizzly Adam Guest
    He's got an excel file that he wants to double check the maths on and we will post it as a reaource tomorrow. Javascript version likely this weekend.
  10. yooperdave
    Once I put the clean on this vintage Star movie theater popcorn machine, we will never run out of popcorn on this site!!!
    [​IMG]:popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn::popcorn: (you get the idea)
    Ashwatcher, milleo, HDRock and 5 others like this.
  11. Sean
    Sean
    Cool I look forward to checking it out. Thanks for thinking about the gang Woodsnwoods
  12. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I just want to say one thing, the spreadsheet will rely on some basic assumptions from you. Even then it does not compensate for moisture content of your wood, etc. The intent is to say I start the season with X btu's based on my feel of the species I have stacked, I end the season with Y. Based on the difference between the 2, you get the btu's consumed. From there you back calc for the efficiency of your wood burner, and apply those btu's to the efficiency of the oil or propane units. Convert those btu's into gallons and apply incremental cost of the oil or propane and heat content of the fuel and there you go. There are ways to do this that are far more complicated, but I did not have time for that exercise and I wanted a rough idea on what I am saving. It is a great way to justify expenses to my wife. If I saved $3000 a year on oil, and lets say I spent 300 on gas oil maintenance etc on my equipment that leaves me $2700 in savings. Those savings justify my new wood shed, or my splitter, a new MS 660 etc :dex: If you find an error, please let me know.
  13. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I think this will be posted sometime today.
  14. Grizzly Adam
    Grizzly Adam Guest
    Yeah, after I get home from work.
    NortheastAl likes this.
  15. Grizzly Adam
    Grizzly Adam Guest
  16. Oldman47
    Oldman47
    Illinois
    You should be able to do that with a spread sheet and a connected input sheet for specifying species, cords, cost per gallon for fuel, etc. It would need a lookup table for selecting the species so that you would have consistent results.
  17. Grizzly Adam
    Grizzly Adam Guest
    J1m, fox9988, Jeffrey Svoboda and 2 others like this.
  18. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Looks good!:dex:
