What will the pellet burners choose for their primary source for 2016/17? W/poll
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by jtakeman, Oct 2, 2016.
What your primary going to be
Poll closed Oct 30, 2016.
  1. Petroleum fuels(NG/Oil/Propain)
    2.0%
  2. Petroleum and pellets
    38.8%
  3. All in with pellets
    55.1%
  4. None of the above(Heat pump-Solar-Switch back to Wood-Ect.)
    4.1%
  1. jtakeman
    Farmers Almanac says more of a typical winter this year. With cold spells and snow projected. Pellets at or above last seasons starting $$$ and Fossil fuels seem to be holding steady. What y'all gonna run with?
    I'm all electric so I'm sticking with pellets. No other choice for me besides some firewood for emergencies! All Electric crowd seem to be the pellet guys niche? Maybe I should look at investing in a furnace or a heat pump........
  2. will711
    will711
    Pocono Mts.
    Same here Jay , all in with pellets .
    savemoney, imacman, CleanFire and 6 others like this.
  3. bostonfan49
    bostonfan49
    Essex Junction, Vermont
    Probably 85% pellets, rest forced hot water/oil. T-Stat starts the shutdown at 10:45 PM and starts up at 5AM. We set our bedroom t-stat (oil) real low overnight, usually use an electric blanket on super cold nights. The only time we use any appreciable amount of oil is if we go on a trip....
    Haven't turned on yet, not expecting my pellet delivery for another 2 weeks! I have enough pellets at the bottom of my 2 bulk bags to last a couple of days.
    Bill
    savemoney, gbreda, imacman and 8 others like this.
  4. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    wood and pellets......you need more choices on yer survey
  5. slvrblkk
    slvrblkk
    Northampton, PA
    X3...all electric here too.
  6. jtakeman
    I would need to start a new thread for additional choices. Didn't want it to get too busy. More a fossil to pellet comparison. Added an other JIC some might take another route. Guess I should of added a "pellet and wood" as I an several have the wood as an option.
    I'd like to go heat pump in the future and use pellets or wood as a filler in extreme cold. If pellets prices get much higher, It might be sooner than later.
  7. MtDew
    MtDew
    Perkasie, PA
    x 4 All electric here as well. I hope the almost 13 ton of fire sale pellets gets me thru!
    Russell, savemoney, will711 and 7 others like this.
  8. Scotty Overkill
    A diet mainly of oak, locust and hard maple and......oh, wait....wrong forum.....:emb:
    Good post guys, keep those pellet stoves crankin'!
    Russell, savemoney, gbreda and 7 others like this.
  9. jtakeman
    You can vote, Dems big pellets tis all! :D
    LongShot, Russell, savemoney and 9 others like this.
  10. bogieb
    Expensive propane here (yes I know, the rest of the country it's cheap). Plus, FHW is only run for upstairs. Will be running all pellets. Will use a little propane for DHW and to run the FHW a couple of times a day during really cold spells (pipes run thru garage), or if I go on vacation.
  11. ttdberg
    ttdberg Pellet Pig
    CT
    Oil and pellets. With oil price still low, we will use it more liberally than usual.
  12. 343amc
    343amc
    Northeast Lower Michigan
    Probably the same as last year 70/20/10, pellets, oil and wood.
    Those numbers are subject to change based on what Mother Nature and OPEC have in store for us.
  13. CleanFire
    CleanFire
    Currently estimating 85/15 pellets & oil here - but depending on the severity of the winter, oil use may increase by necessity: to keep the mechanical systems heated in the crawlspace.
  14. imacman
    imacman
    Denver, NC
    Wish I had a little pellet-burner in the shack, but will have to make do w/ propane. :confused:
    Russell, savemoney, CleanFire and 3 others like this.
  15. jtakeman
    I figured you'd be CL it for one? Even if its only an option down the road. I bet you already got pellet storage all figured out!!
    BTW, How'd you get over the sickness? :hair:
    savemoney, CleanFire, gbreda and 5 others like this.
  16. Ambient
    Ambient
    Northern New York
    We'll stay with the normal format. Pellets (voted) with a supplement of wood(couldn't:confused:) in the wood stove for those below zero nights.
    Russell, savemoney, CleanFire and 4 others like this.
  17. IHATEPROPANE
    IHATEPROPANE
    Perhaps that lowes deal would suit you.
    I should also mention probably 95% pellets 5% electric space heaters as needed.
  18. imacman
    imacman
    Denver, NC
    Can't get it here. Best option for me would probably be a cheapie used unit off CL. Don't have a big place, so something small would do, but again, the price I pay now for propane and a 95% AFUE rated gas furnace means the cost for each is very close. Not having to store & lug bags, or clean the stove makes it a no-brainer for me, at the present time.
    savemoney, CleanFire, gbreda and 3 others like this.
  19. IHATEPROPANE
    IHATEPROPANE
    If they made a hopper extension for that puppy I would be all over that deal. But in your situation, I would do the same as you.
  20. jtakeman
    Luggin bags helps keep the beer belly trim! :D
    Jealous pete, I'd jump in if it was going to be = or less $$. Keep the pellet as backup/filler. Likely go heat pump if we stick here. But got a feeling we be snow birds at some point.
