New Glass Day
Discussion in 'The DIY Room' started by Grizzly Adam, Oct 1, 2016.
  1. Grizzly Adam
    Grizzly Adam Guest
    Breakfast is baking and I am about to pull the sashes in the living room and head to the hardware store for new panes. We currently have what is known as antique glass, so it is about 1/3 the thickness of modern glass. Hoping this will really help the draft problem in this room. I will be doing the glazing myself, recaulking around the top pane, and adding some bulb weather stripping to the bottom of the bottom pane.
    raybonz, schlot, NortheastAl and 8 others like this.
  2. papadave
    Good thinking Grizz. Anytime windows can be tightened up is a good thing.
    Drafts will kill the comfort level in a room.
    raybonz, schlot, NortheastAl and 5 others like this.
  3. Well Seasoned
    Have fun - should make a big difference this winter!
  4. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Good luck Grizz. Keep us posted on the results.
  5. Scotty Overkill
    Sounds like a job, but the benefits will be well-worth the work.
  6. Grizzly Adam
    Grizzly Adam Guest
    Yeah, big job but at least i can work in comfort in the living room
  7. papadave
    Need to git 'er dun quick, before it gets too chilly. It's getting close.
    Although, we were putting in my new windows in the middle of December last year.
  8. Grizzly Adam
    Grizzly Adam Guest
    Change of plans-- not removing antique glass after all. There is enough room to add an additional pane, so I am cleaning these ones up real good and making double panes.
    raybonz, Woodwidow, wildwest and 7 others like this.
  9. Well Seasoned
    Nice!
    NortheastAl likes this.
  10. milleo
    milleo
    Do you have enough space to have air space between the two panes?
  11. Grizzly Adam
    Grizzly Adam Guest
    Yeah, im using the lead glazing that was originally there to act as a spacer between the panes.
  12. papadave
    That makes things even more interesting.
    :popcorn:
  13. Grizzly Adam
    Grizzly Adam Guest
    Ok, i got all the lower panes installed. Tomorrow I will start glazing the inside of the existing upper panes, but we still need to have those panes cut.
  14. NortheastAl
    NortheastAl
    Putnam County NY
    Sounds like you'll get better insulation and no drafts with the double pane setup. The only thing I'd worry about is any humidity trapped between the glass. Might condense and frost in colder weather.
    raybonz and Well Seasoned like this.
  15. Grizzly Adam
    Grizzly Adam Guest
    It already does that with the single pane in the cold months.
    Well Seasoned, HDRock and NortheastAl like this.
  16. HDRock
    When I was a kid we had 8th inch thick ice on the inside, a quarter of the way up the window
  17. Eric VW
    Well, that's 'cos you're old......:BrianK:
    :rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol:
    J/K Rock.......:yes:
    walt, milleo, Well Seasoned and 2 others like this.
  18. HDRock
    Ah, watcha say sonny, can' t hear ya, I got an ear infu**tion :BrianK:
    For real!
    papadave, walt, Eric VW and 2 others like this.
  19. Grizzly Adam
    Grizzly Adam Guest
    Yeah, we get that!
    HDRock, milleo, NortheastAl and 2 others like this.
  20. Woodwidow
    Any before and after pics????
