Stihl 009 find
Discussion in 'Chainsaws and Power Equipment' started by Smokinpiney, Sep 27, 2016.
  1. Smokinpiney
    Smokinpiney
    "South" Jersey
    My uncle passed away a few weeks ago and while going through a trailer he has on my property i came across an 009 in pretty decent shape. It was locked up tight but after a good wd40 soak, the piston freed itself. It had good hot spark so i hit the carb with some spray and she fired right off!
    The fuel tank was obviously drained before he stored it so i gassed it up but it wouldn't run on the tank. One tug on the fuel line and it came right apart so I'll throw new line and a filter on it next. My question is, what the heck is this little brass screw? It was in the very middle of the line?
  2. Well Seasoned
  3. Thor
    Thor
    Genoa City,Wi
    I have no idea, but maybe he plugged it since he knew he would not be using it for awhile? Again I have no idea this is just a guess.
  4. dougand3
    dougand3
    North Alabama
    There should be 2 lines coming out of the fuel tank. One is fuel delivery to the carb - it should have a weighted pickup body in the tank. The other is a tank vent. The screw is probably the tank vent insert. Any kind of tank vent should work. I use Echo vents quite a bit.
    Hammy, Scotty Overkill and cnice_37 like this.
  5. cnice_37
    cnice_37
    Yup, tank vent
    Hammy and Scotty Overkill like this.
  6. Kevin in Ohio
    Kevin in Ohio
    It's original as that is what Stihl used on them. As stated, tank vent screw.
  7. Scotty Overkill
    Yep tank vent, screw belongs in there.....
    Nice score on a good little saw.
    Hammy likes this.
  8. Smokinpiney
    Smokinpiney
    "South" Jersey
    Sorry I didn't say thanks earlier guys. Today i worked on the saw again and replaced both lines. After taking the carb apart a few times, flushing the tank and some cussing i finally got it running but it's gonna need a carb kit for sure. Then my dad walked in with another 009 that he grabbed at an auction for $2. I tore into that one as well but it also needs a carb rebuild.
    Looks like the carb is a walbro wa 56-a. I searched the web but im only coming up with kits for a wa 56-1. The kit looks the same though. Any thoughts
  9. dougand3
    dougand3
    North Alabama
    K10-WAT is the kit you want. It covers lots of WA and WT carbs.
  10. Smokinpiney
    Smokinpiney
    "South" Jersey
    Awesome, thanks for the info doug
