Well project done......
Discussion in 'Everything Else (off topic)' started by Well Seasoned, Sep 25, 2016.
  1. Well Seasoned
    The one well anyway.....
    Dawn and I worked on making the well a little more nice looking and to keep the little dog, Saucy from getting into it.
    Before.......
    just an unsightly death trap for Saucy.........
    After.......
    We framed the opening, I built a door, and rode around picking up rocks from all over. 20160925_143933.jpg
    Any woman needs to put her finishing touches on a project.
    Here lies "The Well" :yes:
    Star Gazer, Gasifier, XXL and 23 others like this.
  2. thewoodlands
    thewoodlands
  3. Well Seasoned
    Maybe for irrigation since it's near the field I'll eventually prep for planting. The other well is really nice, and I plan on adding a cover or housing of some sort with a manual pump. This is the area I'm now starting to clear. There's just not enough time in the day when juggling so many projects. In a few minutes, I will insulate around the main well pump that feeds the house in the crawl space.
    Star Gazer, wildwest, Eric VW and 8 others like this.
  4. Well Seasoned
    While insulating, I was trying to figure out why the lamps wouldn't turn on that keep it a little warmer around the pipes and pump. New light bulbs, check.... plugged in, check....... switches on, check.....
    I unplugged everything and finally figured out that the outlet had a thermostat on it....COOL! I wish I knew these things were invented back at the other house! No more turning on at night and turning off during the day. When temps decline, lights turn on! I'm sure Backwoods Savage already knows of these things, but what a convenience.:yes:I'll still need to check the bulbs aren't burned out though. :rolleyes:
    Star Gazer, wildwest, Eric VW and 9 others like this.
  5. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    Well done!
    cnice_37, wildwest, Eric VW and 4 others like this.
  6. My IS heats my home
    My IS heats my home
    Albany, NH
    The finished project looks great! Pooch is safe too
  7. Backwoods Savage
    Also need to be aware led bulbs don't give off the heat like the old light bulbs. That could be a problem.
    Star Gazer, wildwest, Eric VW and 7 others like this.
  8. Boomstick
    Boomstick Banned
    Saratoga county ny
    I hoarded some standard bulbs, but I use them for similar situations. You can find small heat bulbs thatll work.
    I always heard from my grandfather to never fill in a good well.
    They can be dangerous (don't fall into any other unknowns)but the finished work looks good!
  9. papadave
    My thought as well Dennis and Boomstick.
    My wife just got some new guineas, and her old bulb stopped working, so she needed a new one. They're still available, but few and far between, and won't be around too much longer.
    I bought her a 4 pack, and should have grabbed 3-4 of them.
    Well Seasoned , it's good that you thought enough to insulate the pump pit/house.
    My SisIL has had her line freeze twice, and that was during last winters mild (comparatively) weather.
    I think she got around to adding some more insulation and put in a hotter bulb for this winter.
  10. savemoney
    Hope the wood isn't PT. You don't want chemicals leaching into the well water. If it is PT. consider putting on some plastic on the back or find some way to seal the wood with some none toxic coating so it won't leach through into the water. Just my 2 cents of precaution.
  11. Horkn
    Exactly. You need a halogen, or at least an old school filament bulb to make the heat.
    LEDs make little heat at all. CFL bulbs make a little more, but you want the old tech in this case.
    I use a 100w bulb in the dog house of my ski boat to keep it all happy when it gets to freezing temps overnight before I winterize it with RV antifreeze and still can use the boat.
  12. Well Seasoned
    I hoarded enough of those bulbs, yes they are getting harder to find, and I think I'll get more when I see them. I also have a thermometer wire fed down there with the screen by the back door with an alarm. If a bulb goes out, I'll know ahead of time.
  13. Well Seasoned
    This crossed my brain. I do have plenty of 6mil plastic I can attach to the underside.
  14. Scotty Overkill
    Now, to freak out your guests, all you need to do is make up a headstone that reads something like "Here lies Hatchet Jack.......he kilt the bear that kilt him...."
  15. Scotty Overkill
    Looks good, by the way! I'm a sucker for natural stone work as you well know!!
  16. Well Seasoned
    Now that sounds fun!
    Thanks man.......how's your WFO coming along?
  17. yooperdave
    Great movie!!
  18. Smokinpiney
    Smokinpiney
    "South" Jersey
  19. milleo
    milleo
    You are going to have to be really careful till you know how cold it gets down under where your pipes are...It gets really cold where your living now....
  20. Scotty Overkill
    slow. But lining up the concrete work for the patio and WFO foundation as we speak.......
