Moen shower stem - plastic or brass replacement cartridge!
Discussion in 'The DIY Room' started by don2222, Sep 23, 2016.
  1. don2222
    don2222
    Salem NH
    Hello
    There was a plastic cartridge in the shower that lasted only 2 years
    When I went toHome depot, I only saw 1 plastic and one brass, the brass Moen # 1200 was for about $22 was thin and would not fit so I got the wider plastic for a whopping $39 and popped it in.
    Nice change out video on YouTube
    Now I see this on the web and it says it replaces the plastic? Would this work and last longer
    Danco Cartridge 80993TS
    Plastic
    Moen # 1222
  2. Canadian border VT
    why didn't you just call Moen they send you free replacement parts? unless you did not want to wait for post office to deliver..
    Stihl Livin likes this.
  3. Butcher
    Butcher
    If I understand your post correctly you said the brass Moen #1200 would not fit, right??? The add for the Danco cartridge says it is a replacement for the Moen #1200 that you already stated would not fit. Or am I missing something here?
  4. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    You can replace the black pads and o rings and keep the stem unless it is all pooched. If it is not a genuine Moen, the quality and fit may not be the same. They will work, but not the same as genuine. Make sure the balancer spool inside still jiggles.
    There is a puller tool available, since those stems can be hard to remove.
    SKEETER McCLUSKEY likes this.
  5. fishingpol
    fishingpol
    That replacement does not look like it would work. You need the ears to fit in the valve body by the retainer clip so it does not spin.
  6. Well Seasoned
    We've got so many diy hoarders here always willing to lend a hand! :handshake: I love it!:yes:
    don2222 likes this.
  7. don2222
    don2222
    Salem NH
    Thanks
    I guess I am stuck with the plastic 1222 then right?
    Well Seasoned likes this.
  8. fishingpol
    fishingpol
    The plastic one is fine, it will last many years. I'm just curious why the brass replacement one is a smaller diameter.
  9. Stihl Livin
    Stihl Livin
    Minnesota
    The brass cartridge is for the older Moen faucets where the face plate screws are both on the bottom and not kiddy corner from each other. I would still call Moen and have then send you a free cartridge for a back up. If the cartridge didn't last as long there must be some hard water in the area. Hard water and plastic do not go well together.
