Getting a new truck, compare RAM EcoDiesel vs F150 Platnum??
Discussion in 'Chainsaws and Power Equipment' started by Machria, Aug 22, 2016.
  1. 94BULLITT
    94BULLITT
    Frederick County, VA
    Don't have it, but I could have it in the morning. We don't stock a lot of filters, just the stuff that is popular for us. Most customers call ahead and schedule an appointment for an oil change.
    clemsonfor and Horkn like this.
  2. Boomstick
    Boomstick Banned
    Saratoga county ny
    So they use basically a old school outdated Dino spec oil?
    Did you mis-quote copy? The post further down states that just about any oil will meet the old spec?
    We never use anything other than the cheap stuff at Walmart for VW.
    The Mrs has 235k on the passat. What kind of trouble am I in for?
    clemsonfor likes this.
  3. DexterDay
    They already have EGR delete for this truck, as well as different tunes. So whether it's "different" from the new Cummins, Powerstrokes, or Duramaxs? It's not... Every semi produced today uses DEF. . You think they still won't go 1,000,000 miles?
    clemsonfor and concretegrazer like this.
  4. Horkn
    Around here, you can't EGR delete, or any emissions related mod on any newer diesel. I think it's 07 + that even diesels need to pass emissions, unless it's a heavy truck. Any 1500 isn't heavy enough to not have to take emissions tests.
    Those are a severe pita here.
    JustWood and concretegrazer like this.
  5. Horkn
  6. concretegrazer
    concretegrazer
    Southwest MO
    The engines themselves will be fine. Until they have to downsize them to get them to run hotter. The emission systems work better under load. So long haul rigs should have less trouble. Delivery trucks ext. are having issues. Excessive idling is bad for these systems. Though not as bad with def compared to regen. So drive it like you stole it and you'll probably get along fine.
    MasterMech, Horkn, mdavlee and 2 others like this.
  7. eatonpcat
    Is there any other way?
    DexterDay, Horkn, clemsonfor and 2 others like this.
  8. JustWood
    JustWood Guest
    Same here. Kids were buying up all the used dietsels . Doing a delete. Adding dewlly stupid staxxs and rolling coal ,,,,, TILL their next inspection was due!!! Don't see any stewpid staxxs rolling coal any more . BOOM! :thumbs::thumbs::thumbs:
    Horkn, Boomstick, brenndatomu and 4 others like this.
  9. bassJAM
    bassJAM
    Cincinnati, OH
    Oh, sure, pick on me!! Is it because I think the Ridgeline qualifies as a truck? lol
  10. clemsonfor
    No but those big trucks have their share off issues. Most all loggers I have that bought those tier 4 trucks have got rid of them or just bear the trouble associated with them. Many just keep rebuilding the older ones.
    One logger I have...not that big of one. Buys a chasis/cab from freightliner and buys a motor from a yard and then puts the motor in the new truck and rebuilds it all at the same time. So he had a new truck with an older cummins diesel in it. Still the computer controlled ones but without all the tier 4 crap
  11. brenndatomu
    I had heard that EPA or somebody put the stops to that now...
  12. clemsonfor
    What rebuilding old engines or buying chasis and installing an older motor? This was just last summer I beleive he bought those 2 trucks. Brand new. Plastic on the seats and a box on the back with the needed parts to be installed once the motor was in place.
  13. brenndatomu
    Buying glider kits. A local dairy with a large truck fleet was buying gliders somewhat regularly but I had heard that EPA had closed that little loophole once they figured out that people were sidestepping the new emissions engines in the process. I dunno...just what somebody told me...I guess I should look it up...
    Horkn likes this.
  14. clemsonfor
    That what he called it a glider. But didn't use that term as I wasent sure exactly and didn't know if folks here would know.
    Horkn and Boomstick like this.
  15. clemsonfor
    Diesel has been close in price here and I had noticed awhile back was a bit cheaper. Then gas droped but I think gas has crept back up due to the pipeline ordeal.
    Horkn, mdavlee, Boomstick and 3 others like this.
  16. Boomstick
    Boomstick Banned
    Saratoga county ny
    Most reputable performance shops can do a tune, you can buy a programmer or find someone with EFI live or hptuners.
    Delete every emissions peice on the truck, pick up some hp and mpgs without any other changes.
    A handheld can work, switching between stock-tow haul-economy is useful.
    There are emulators too which is the cheapest but I've had them fail.
    I think you can replace with a pre dpf exhaust(boneyard e-bay) piece +tune or emulator but dont quote me.
    Thor likes this.
  17. JustWood
    JustWood Guest
    Holy chit! Cheapest around here is $2.44 . And one of PAs largest refineries 45 mile away!
  18. clemsonfor
    Bring your tank down here then. :) we can hang out and I'll give you a place to stay. Haha , remember that's onroad. Offroad is 20 cents or so cheaper.
  19. brenndatomu
    I heard eatonpcat has a rare form of dyslexia where he drops the first letter off of words...he simply misread your user name... ;) :whistle: :jaw: :doh: :picard: :p
    Horkn, 94BULLITT, Barcroftb and 4 others like this.
  20. brenndatomu
    This reminded me of something I have noticed in the past, you can often tell what diesel engine is running by the smell. Old JD tractors were distinct from a Ford, and a 7.3 Powerstroke smells completely different from a 5.9 Cummins...etc.
    Horkn and Canadian border VT like this.
