Stihl 029 Farm Boss issues
Discussion in 'Chainsaws and Power Equipment' started by mtkeg, Sep 7, 2016.
Tags:
  1. mtkeg
    mtkeg
    Poynette
    The saw is 17 years old and the only repair I had done is repair of the choke mechanism. So it has served me well until recently. The last few times I used it, it ran fine until I shut it down for a break or to refill gas/oil. It would not restart unless I let it sit for quite a long time. Then ran fine until shutdown again. Took it to Stihl dealer and was told the piston was scored and repair would be $280 - $350 depending on cylinder condition. Bought a replacement saw instead. But, would this really cause the issue I was experiencing? I kept the old saw and am trying to rebuild it myself. I opened the crankcase and pulled the piston. Aside from carbon on the top of the piston, it looks fine to my untrained eyes. Same with cylinder. Where else should I look for problems? It was a pain to tear down so, as long as it is apart, what all would you recommend be replaced.
    Woodsnwoods, pantelis and TurboDiesel like this.
  2. Oldman47
    Oldman47
    Illinois
    If you don't have piston/cylinder problems I would still use new rings and reassemble. For an old saw you might want to check out the fuel line and fuel filter. Those bits tend to deteriorate over time. Another possible weak spot with age is any rubber items like the connection between the carb and the inlet port. It doesn't take much of an air leak/crack to make the engine run like sh!t.
    Woodsnwoods, mtkeg and TurboDiesel like this.
  3. Mag Craft
    Did you ever pull the spark plug out when it would not start to see if it was getting any gas. Could have been flooding out.
    The dealer sounds like they were spittin in the wind. So all the piston skirt surface looks good with no vertical marks on it.
    Woodsnwoods likes this.
  4. TurboDiesel
    Welcome to the club, mtkeg.
    I think your gonna like it here.
    Help is on the way
    Woodsnwoods and mtkeg like this.
  5. MasterMech
    Post a pic of the parts you have. Especially the sides of the piston. Low compression could indeed cause the hot restart issue you describe but it would generally be accompanied by rough idle/stalling, difficulty tuning and a noticeable lack of power. The 029S is no ball of fire in stock form so the lack of power would have been pretty noticeable unless you were cutting small wood only.
    If indeed the engine is toast, the option to put it back together as an 039 (64cc vs 56) would be tempting. Complete aftermarket engines or piston/cylinder kits are available for cheap.
    And just to satisfy our curiosity, what did you get as a replacement saw? :D:saw:
    Woodsnwoods, pantelis, Hammy and 3 others like this.
  6. Khntr85
    Khntr85
    To the OP, hello you will like it here....You will also have twice as many saws as you do now excactly a year after joining this site LOL....
    There are a lot of knowledgeable chainsaw guys on this site.... As a matter of fact Mastermech is one of them!!!!
  7. mtkeg
    mtkeg
    Poynette
    Thanks for the responses. Pics are attached. Replaced with another Farm Boss - MS271. Qualification - I just retired and never messed with small engines prior to about a month ago when I decided to mess with my tiller. Rebuilt the carb and it now purrs. So, no I didn't try to diagnose the issue outside of cleaning the air filter. Just took it to the dealer.
    So, what is your opinion? Is the piston toast?
  8. Mag Craft
    That piston looks to be in great shape. I would put some new rings on it and some new crank seals since you have it apart. By what the piston looks like I assuming the cylinder looks good also.
    You could still have a carb problem but will not know until you get it back together.
  9. Barcroftb
    Barcroftb
    The Mitten
    I agree that piston looks good. Could be an air leak somewhere else. Intake boot, seals, bearings, impulse line, etc. Or more likely it could be a carb issue.
    It may be time to pick a different dealer though. At the minimum they misdiagnosed your problem. Worst case scenario they purposely jacked up the repair price to sell you a new saw. I've seen this happen before with friends and family.
    Woodsnwoods, pantelis and Hammy like this.
  10. mtkeg
    mtkeg
    Poynette
    OK. I pulled the paperwork on the old saw and I guess I mis-stated the dealer diagnosis. Sorry about that. They reported " intake manifold was leaking causing lean running conditions. Scored wall. Could possibly hone cylinder but best bet is to replace it." I'd swear they said piston over the phone.
    It's hard to get a good pic of the cylinder but there are some vertical lines at the top of the exhraust side of the cylinder. it feels smooth when I run my finger across it though.
  11. Khntr85
    Khntr85
    I agree with that the piston will work for sure, as stated new rings and seals....
    Woodsnwoods and Hammy like this.
  12. mtkeg
    mtkeg
    Poynette
    So, fuel line/filter + rings+ seals. How about the intake manifold which dealer kind of implied as the problem? Inspection reveals no cracks/holes. Or carb which some feel might be contributing. Do you recommend OEM parts or are after market OK?
  13. MasterMech
    Manifold will need to be pressure tested to confirm one way or the other. You could replace it if you have no means to confirm the dealer diagnosis.
    Don't be afraid to take some light sandpaper or scotchbrite to the rough spots inside the cylinder. You won't hurt it a bit smoothing it out by hand.
    pantelis, Hammy and Barcroftb like this.
  14. Mag Craft
    Just from the looks of the piston I doubt that the cylinder has any serious damage to it. Like MasterMech said do not be afraid to use some fine grade sandpaper or scotchbrite to smooth out the cylinder wall.
    The fact that you cannot feel the vertical lines on the cylinder with your finger tells me there is nothing wrong with the cylinder.
    If the lines were deep above the exhaust port you would have lost some compression and that does not sound like the case to me.
    Like BarcroftB said time to look for another dealer.
  15. mtkeg
    mtkeg
    Poynette
    Thanks again. Any opinions on OEM vs. after market?
  16. Barcroftb
    Barcroftb
    The Mitten
    What's your goal with fixing the saw? Back up saw? Fix it and sell it?
  17. mtkeg
    mtkeg
    Poynette
    Backup saw.
    Hammy likes this.
  18. Barcroftb
    Barcroftb
    The Mitten
    Guys have had some luck with aftermarket stuff. For a back up saw I don't see any reason why not.
    pantelis, Hammy and TurboDiesel like this.
  19. Mag Craft
    I would keep the cylinder and piston you have it will work just fine and still provide years of service for you.
    New rings, crank seals, fuel lines, intake boot. That is what goes bad.
    concretegrazer and Hammy like this.
  20. mtkeg
    mtkeg
    Poynette
    Got the parts ordered. I'll post back with the results of my rebuild when I get this put back together again. Thanks again for the input. :salute:
    milleo, Barcroftb, Mag Craft and 2 others like this.
