Not Following the Rules
Discussion in 'The Wood Pile' started by Kimberly, Jun 25, 2016.
  1. papadave
    Beautiful. Go get it!
    Horkn and Kimberly like this.
  2. milleo
    milleo
    Lol....Coool you admitted it....:thumbs:
    Sean, Horkn, Eric VW and 1 other person like this.
  3. milleo
    milleo
    Why you cutting oak right now....You need something that is burnable this season...:eek:
    Ashwatcher, Horkn and papadave like this.
  4. Kimberly
    Kimberly
    The Kangaroo State
    It was dead, been dead at least a couple years I think. I figure if I cut it and split it that it would have a good chance on drying out :confused::(
  5. yooperdave
    Didn't anyone tell you?
    That's for cutting on the other side of the log.
    Sean, Ashwatcher, Horkn and 3 others like this.
  6. papadave
    Or, an alternate universe.
    Horkn, Eric VW and yooperdave like this.
  7. milleo
    milleo
    Maybe...And hopefully for you...
    Horkn, Kimberly and Eric VW like this.
  8. yooperdave
    The laws of nature do not cease to exist in Va.
    The stove will still require dry wood. In my experience with dead standing trees, I have only come across one small maple in the years I have been burning EPA stoves that was actually ready to be burnt inside the stove. It was cut down in the early spring (still some snow on ground) and before the melt started in earnest.
    Ashwatcher, Horkn and Kimberly like this.
  9. Kimberly
    Kimberly
    The Kangaroo State
    Well, I am a scientist; perhaps we can work out the laws of nature. I do know that increase surface area means more area in contact with the air which means quicker drying. Therefore, I need to get it split ASAP.
  10. milleo
    milleo
    I have worked with oak that I would have sworn was dead and dry but nope....Moisture meter said no way...
    Horkn, fox9988 and Kimberly like this.
  11. Kimberly
    Kimberly
    The Kangaroo State
    I don't think the laws of physics apply here; more like the laws of chemistry and thermodynamics. :D
  12. Kimberly
    Kimberly
    The Kangaroo State
    Yes, I know. I split a piece of that red oak and left it in the shed. I think I will split it again and do a moisture test. The problem is that is no real good place here to stack it that would get some good hours of sun. We didn't get as many of the trees down when setting the house up; I hurt my back and it put me out of commission. We were being pressured to get the house off of the dealer's lot because of insurance.
  13. brenndatomu
    So what was it?! Can't put us through all that and no details! :hair:
    Kimberly, Horkn and Eric VW like this.
  14. Horkn
    No, I'll sweat. That's why I won't cut when it's hot out.
    Being in the hole though wood wise with heating season knocking on your door, I applaud your efforts to keep cutting. :)
    Ashwatcher, Kimberly and fox9988 like this.
  15. fox9988
    fox9988
    NW Arkansas 72717
    Same here. Processing wood is enjoyable under the right conditions, miserable in others. Another advantage to being years ahead.
  16. Horkn
    In my experience, oak is not a good wood to try to rush.
    It holds moisture so well, that it will take years to dry, even if dead standing, or simply not split.
    papadave, yooperdave and Eric VW like this.
  17. Eric VW
    Testify!
    :D
    papadave, Horkn and yooperdave like this.
  18. yooperdave
    One piece does not a warm Kim make. Ya gots to split 'em all.
    Whats the shed got to do with it? Dry storage? Leave it outside.
    milleo, Kimberly and Horkn like this.
  19. Horkn
    There's been some dead standing trees that will be ready even that year, at least a few feet up from the ground at least. Elm that's dead standing barkless, and with long vertical cracks in it will surely be dry enough to burn in an EPA stove pretty much as soon as it's cut and split.
    Wood like that is about as close to being CSS'd as mother nature allows. ( Time in the stacks will only make it better though.) :yes:
    yooperdave, Ashwatcher and Eric VW like this.
  20. Kimberly
    Kimberly
    The Kangaroo State
    I put new points and condenser and adjusted the timing and clean connection points and ground and drain the fuel and replace it with fresh. So I guess it was all that stuff; I don't know. These 8Ns can be a mystery at times.
    Horkn likes this.
