Question on an insert/WFO combo
Discussion in 'Modern EPA Stoves and Fireplaces' started by swags, Oct 4, 2013.
  1. swags
    swags Moderator
    OK So I have always wanted a wood fired oven in my kitchen, but I also want a stove or insert in there. So my current situation is I have an existing chimney that I can get an insulated liner dropped in and I am curious if I can make a custom stove/WFo combo that share the flue. My thought is to have a T that I can change the flue from the oven to the stove. Is that possible? or could I just have both of them fed into the same flue? I could put a damper in to close off one of them while not in use. This would solve my problem of wanting both butonly having one flue to run. Any thoughts?
  2. Fyrebug
    Fyrebug
    I think by code you are not allowed to share one flue with two appliances.
    These guys are 'somewhat' competitors of us but I dont mind giving them a plug. They make a very clean burning wood oven at a reasonable price. I think Obadiah's web site sells them in the USA. It can double up to heat up your house.
    http://jaroby.com/en/fiche/9/198/
  3. NortheastAl
    NortheastAl
    Putnam County NY
    This is a cool cook stove. Was on the old site, but worth a repeat.
  4. swags
    swags Moderator
    What kind of price on the cookstove you linked?
    t
  5. tlandrum
    tlandrum
    I sold the Elmira brand stove back in the day. they were absolutely beautiful stoves.
  6. Fyrebug
    Fyrebug
    http://woodstoves.net/cookstoves.htm
    See link above. They have a whole bunch of different models.
    BTW, I'm about 20 Min drive from Elmira Cookstoves. They have gorgeous units but pricey..
