Enviro Low Limit Snap Disc Debacle on M55 and Maxx - What would you Do?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Aug 22, 2016.
  1. don2222
    don2222
    Salem NH
    Hello
    Lately I have seen failures of those mini 120 Deg F OEM ceramic discs used as proof or fire (Flashing Heat Level 3) light also used to turn on the convection fan or room blower in the Enviro Maxx and Enviro M55.
    Now Breckwell stoves also use the mini 120 ceramic snaps and I have changed quite a few there too. The Breckwell exhaust housing can be changed to a housing with a larger hole quite easily.
    Now those good old Travis pellet stoves use reliable 120 Deg F full size 3/4 inch ceramic low limit snap discs that last a very long time. Even Napoleon and Whitfield use 3/4 inch 140 Deg F ceramic snap discs. With tolarances of +or- 20 Degs the spec of 140 is really not much different here.
    Interesting enough the Enviro Maxx has a hole large enough in the exhaust blower housing to accommodate the large disc. Is Enviro short changing us here?
    The M55 has a smaller hole in the exhaust housing but by using a step drill bit, this hole can be easily expanded to accommodate either the larger 3/4 inch snap disc or the small mini snap disc.
    In both stoves, the stove started with a nice fire and and then the auger stopped, the fire died out and heat level 3 started blinking.
    The current mini ceramic OEM replacement part is approx $63.00 OnLine part # P/N: EC-001 (Replaces Regency P/N: GF55-009)
    The large and better ceramic snap can be found quite a bit cheaper!
    Now keep in mind that these snap discs are ALL made by 1 or 2 snap disc manufacturers so nothing proprietary here folks really.
    So which would you choose for your stove?
    Pic 1-2 Mini Ceramic 120 Deg F OEM Snap Disc
    Pic 3-4 3/4 inch full size ceramic snap that comes in 120 Deg F or 140 Deg F. That is Beefy!
  2. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    I would toss the little failure prone unit in the trash bin and auger out the hole and install the 3/4 "more durable ones" in a heart beat
    don2222 likes this.
  3. eatonpcat
    Never had a snap disc problem in my stove!
    jtakeman likes this.
  4. don2222
    don2222
    Salem NH
    A clean stove has a happy snap disc!
    eatonpcat and SmokeyTheBear like this.
  5. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    damm, haven't I already told you that?
  6. don2222
    don2222
    Salem NH
    Hey Smoke
    Got your Saranac ready for the another season???
    That is one of the very few newer stoves with a heavy duty 3/4" diameter auger shaft like the old Whitfields have!!!
    Fixing up the convection blower like you did makes that stove a real Humdinger! ! !
  7. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Nope, will have to clean it. Not until I can get down and back up.
  8. jtakeman
    Might be cheaper to run the juice machine??
    SmokeyTheBear likes this.
  9. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    All set to do so.
  10. don2222
    don2222
    Salem NH
    Yea Local Pellet prices could be better.
    Lowe's has
    Easy Blaze $274.50 or $5.49 per bag
    Power pellets $274.50 or $5.49 per bag
    Green Team $349.50 or 6.99 per bag
    $65 for delivery
    See pics
    Heck since East Coast Lumber has free delivery right now the Okie Golds for $275.00 a ton are a good buy and the NEWP for $255.00 a ton are are real bargain!
  11. mike holton
    mike holton
    Old Dominion
    we don't use no stinking snapdisks, hate those things
  12. don2222
    don2222
    Salem NH
    Hi Mike
    Yes one less thing to go bad!!!
    P.S, I just saw your new Smart Stove and it looks impressive for the price tag of $1449.95
    So my question is the 25-IP and where is that headed?
  13. mike holton
    mike holton
    Old Dominion
    its still in the lineup and for the foreseeable future should stay, the unit is very popular up in canada
    don2222 likes this.
  14. nailed_nailer
    nailed_nailer
    Cape Cod
    eatonpcat likes this.
  15. don2222
    don2222
    Salem NH
