2.1 cubic foot stove
Discussion in 'Modern EPA Stoves and Fireplaces' started by Huntindog1, Jan 30, 2014.
  1. Huntindog1
    Huntindog1
    South Central Indiana
    My house upstairs is around 1900 sqft. Heat from the basement family room which is around 700 sqft.
    The stove will do fine until we get extended periods of cold like recently staying minus temps and single digits for extended periods.
    I am now thinking if winters keep coming like this one I am going to get a bigger stove.
  2. fox9988
    fox9988
    NW Arkansas 72717
    That's a lot to ask of 2.1 cuft from the basement. 'Couse it has a lot to do with how much time you spend at home to reload when needed.
    A 2.1 reloaded every 6 hrs should preform as well as a 4.2 reloaded every 12 hrs.
    I bet a BK King would cure what ails you :campfire:
  3. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    Plenty of economically priced larger steel stoves out there. There are at least four other 3 cu ft stove options available to you in the economically priced bracket.
    A larger stove will not just make colder days easier, but it will also make milder temps easier.
  4. Certified106
    Certified106
    In The Hills
    It's hard to beat an NC-30 for price and performance! Sounds like it's time for an upgrade :thumbs:
    Chvymn99 and raybonz like this.
  5. Todd
    Todd
    NW WIS
    I bet a lot of people are thinking of going bigger after this Winter. What about a second stove upstairs?
  6. Oldhippie
    Oldhippie
    Ashby Ma
    Is there no chance of putting the stove in the main living areas of the home? The closer the stove is to the people the warmer they will be.
    Even with a big BK in the basement, you need to generate BIG heat down there to get some of it upstairs. That's not the most effcient way to burn the wood.
    raybonz and NortheastAl like this.
  7. DaveGunter
    DaveGunter
    It sounds like your doing pretty good to me. I'm in a similar situation, 2200 sqft on two floors heated from the basement with a nc30. My basement walls are insulated but not finished and I have about half of it blocked off, so another 600 sqft heated in the basement. The nc30 will keep up in zero degree weather especially if it is sunny also.
    I prefer burning this way. I can bring in as much wood as I want by the wheelbarrow full load through the walk out basement, and store it near the stove in 90-100* space. It keeps the mess in the basement. I don't loose any living space to the hearth/stove. The living space temps are very even, you don't get roasted out of the living space the stove is in. Chimney sweeping mess is not in the living space. I do miss watching the stove from the couch, I'm burning a little more and the trips up and down the stairs tending the stove can get old, but overall I prefer having the stove in the basement.
    Huntindog1 likes this.
  8. Locust Post
    Never a bad idea to think about a bigger stove but another way to look at, is this going to be a norm or is this an unusual winter. I have a couple small ceramic disc heaters in the farthest rooms from the downstairs stove room. Of course I also have natural gas hot water and a new boiler that I can run fairly efficiently. Just rambling and throwing out some thought.
  9. savemoney
    Pellet stove in the living level. You will love it!
    DexterDay likes this.
  10. Backwoods Savage
    For sure you are asking a lot out of that stove. I would be in the market for a larger one.
    As for the winters and what they will be in the future, I still bank on the idea that things will level out. No, we won't get all cold winters like this year but we also won't get winters like we had 2 years ago on a regular basis. There has always been and will continue to be cold winters and relatively warm winters. I say get the stove that will heat your home in the coldest winters and then you'll be all set. I shudder when I read about folks who do well with the stove until it gets down to the low 20's.... Wow.
    papadave likes this.
  11. Huntindog1
    Huntindog1
    Interesting comment, I will have to think about that one for a while. But I was thinking kind of the same thing but it was more in the way of I bet guys with bigger stoves are also struggling.
    Fox9988, Problem with reloading every 6 hours is shoveling red hot coals all the time to get room in the stove to reload.
  12. DexterDay
    X2 :) I love my Wood stove. But before the wood stove, there was my pellet stove. It's still a Primary heat source.
    Why shovel coals every 6 hrs? Run a higher air setting and get more BTU's. Personally, I would never shovel coals from the stove. That's usable heat.
    And I agree with Certified106...
    :thumbs:
    The 30-NC is a monster heater.
    Chvymn99 likes this.
  13. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    Because, when a stove is undersized for your needs you are reloading before the burn cycle is completed. This results in an ever growing mound of coals. I had this problem with the Heritage since it was too small for my needs.
    Chvymn99, Certified106 and DexterDay like this.
  14. weatherguy
    weatherguy
    central massachusetts
    A lot of people thinking of upsizing this year, me included. I was always told you can build a smaller fire in a big stove but not a bigger fire in a small stove. I'm going to take a ride to Woodstock and check them out. A bigger stove will be less fill ups when its milder so its a win win.
  15. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    I wonder how much of a difference you would notice between a 2.85 cu ft stove and a 3.2 cu ft stove?
  16. Oldhippie
    Oldhippie
    Ashby Ma
    Road Trip!! LOL! Say hi to the gang for us up there.. make sure you have time for the tour. I'm also a fan of the 4Aces Diner for lunch, but it's more about the ambiance (Biker Casual with a cute wait staff) than the food.
  17. Certified106
    Certified106
    In The Hills
    Also, if your house heat loss is to high many times the btu output of your stove while burning down coals is to low to overcome the heat loss meaning you lose temps that you then have to make up on the next load....... It becomes a never ending cycle that you really can' t overcome in sustained low temps.
  18. weatherguy
    weatherguy
    Are you comparing the PH to the IS? I know the PH has some power, so far the reviews on the IS are pretty good, tough decisions.
  19. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    I am comparing your Princess to the Steel. Unless you plan on running two stoves?
  20. weatherguy
    weatherguy
    My Princess is an insert and only 2.54 cf, the free stander is 2.85. Both the IS and PH are larger but from what I gather stronger heaters, I'm also going from an insert to a free stander so should gain heat there.
    I could run two stoves but the wife isn't crazy about the idea but not totally against it, or one larger stove. I think the PH and IS because of their design could handle the job alone and are also built to run low if need be, I'd rather tend one stove if possible.
