Calling all plumbers, I need help
Discussion in 'Everything Else (off topic)' started by Well Seasoned, Aug 17, 2016.
  1. Well Seasoned
    Our house sits on a slab, and in the crawl space is the water pump sitting next to a blue tank which sits within the cut out portion of the base of the slab. The hole in which the tank sits in is surrounded by water filled to the top and is over flowing a bit. I suspect that this is no good. Any advice would help before I call a plumber. Thank you
    Eric VW likes this.
  2. savemoney
    Sorry, that is bad news. Do you have some way to pump it out to see where the water is coming from?
    Horkn, Eric VW and Well Seasoned like this.
  3. Well Seasoned
    Not yet........
    Eric VW likes this.
  4. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    Do you have a drain in the pit?
  5. Bret Hart
    Bret Hart
    Central NY
    Water looks reasonably clean so maybe not ground water. Maybe the bladder tank or one of the connections is leaking. Get it pumped out and check for leaks. If you don't have a pump just drop a garden hose into the hole and hook up a shop vac to the other end outside so you don't have the vac under the house in the wet area.
  6. Canadian border VT
    Well Seasoned I cannot tell from pics.. could be ground water or a leak near bottom of tank ..
    Step 1 is get water out of there to see what is causing problem. if you weren't 3 hours away I would grab pex tool and sump pump and be there..
    without knowing layout of house is there a way to get a garden hose out and down to drain area then shut water off (main) this will tell you if water is a leak or ground water ... oh not a plumber but a landlord and that makes you experienced.. pressure tank might be leaking
  7. savemoney
    I'm no plumber and don't pretend to be one. My 2 cents, any hole that is part of a home needs to have some way to drain. Your water pressure tank is submerged in water. That isn't good at all. You need a sump or a drain. The larges issue I see is how did the water get there. We are so dry, I can't imagine it is ground water. Something must have failed. I would hate to have that water short out you water system, or pollute it. If you have a wet dry vac, they often have an port at the bottom where you can attach a garden hose. You could suck out the water and drain it off. Then attempt to find the source of the water.
  8. Well Seasoned
    Thank you for your offer despite being a few hours away! I used the pool pump to get the water out. I dried everything off, pump, pipes, etc ran the water for a while to kick on the pump. It appears that their is a very small drop coming from the pump, but certainly not enough to fill the hole. All the pipes look ok, and all was ok when We had the home inspected here before buying. We just bought this place July 11th and were only here a week and a half, left back to Pennsylvania for 3 weeks and have now moved in here officially for the past 5 days.
    We have received a ton of rain over the past week, so I won't rule that out. I will watch the water level over the next few days and certainly pay attention to any rains we get. A sump pump will likely go in. Next I'll inspect the tank closer. There is rust, but doesn't appear to be any leaking.
    excellent idea on the wet dry vac. I will use it for the remaining bit of water that's in there. A dump pump will be in order for sure! Thank you!
  9. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    you got gutters on the roof??? i know alot of places in NH got quite a bit of rain.....i knocked the elbow off one of my gutter drains with the lawn tractor once......it wasnt pretty next time it rained.
  10. yooperdave
    There are utility pumps that are submersible with just a garden hose hook up for the discharge. This may help removing the water from the pit. Might want to consider a sump pump which would be automatic operation and have to be plumbed permanently instead.
    Sounds like it may be ground water?
    I suppose the pressure tank is already as high as it can be to the floor joists?
    Maybe a horizontal pressure tank?
  11. savemoney
  12. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    If you have that type of pump I would assume your well isn't very deep, so the water table may be quite high. This may be why that hole filled up.
    Horkn, Eric VW, Fanatical1 and 4 others like this.
  13. Well Seasoned
    No gutters........ Next heavy rain I'm outside investigating things. So far the water hasn't risen. We did get a ton of rain.
    Maybe horizontal would be the way to go. There is maybe a half a foot of room to the joists.
    That's a good idea. There is a temperature sensor in the area I saw.
    Your probably right. I don't think the well is especially deep. It's a dug well. I'll need to go back through my files.
    Thanks everyone for your info. I'll keep y'all posted with any findings. :yes:
    Mitch Newton, Horkn, Eric VW and 6 others like this.
  14. Jack Straw
    Jack Straw
    Good luck. We're all in this together.
    Elvisss222, eatonpcat, Horkn and 6 others like this.
  15. Well Seasoned
    Thanks, that's why I love you guys! :thumbs:
    will711, eatonpcat, Horkn and 3 others like this.
  16. Chvymn99
  17. Canadian border VT
    does well have pipe with tag, if so state Agency of natural resources will provide you with depth and gpm.. available onwebsite try to find link..
  18. Well Seasoned
    Thanks!
    Still hasn't filled back up, no leaks, I'm thinking rainwater.... Will check in the morning. :thumbs:
    Horkn, Chvymn99, Eric VW and 5 others like this.
  19. Backwoods Savage
    Then for sure you need a sump pump in there. Good luck.
  20. Well Seasoned
    Thanks! Already pricing a few. Any suggestions on brand or quality?
    Chvymn99, Horkn and Eric VW like this.
