Comparing the Ideal Steel to Progress Hybrid
Discussion in 'Modern EPA Stoves and Fireplaces' started by Flamestead, Dec 12, 2013.
  1. CLL
    CLL
    What length wood can you get into the IS north and south ? Thank's !
  2. Flamestead
    Flamestead
    Windsor County, VT
    18" max with the andirons in.
  3. charlie
    charlie
    Schoharie, NY
    I could agree more on the Ash Pan... No cut corners... even nice roller bearings used on the closing mechanism... I love removing powder instead of coals..
    fox9988 and Tenn Dave like this.
  4. golf66
    golf66
    OK, I know I'm justifying the purchase of the Ideal to myself :drunk:, but....the issue of the ash pan goes beyond convenience IMO. With my current stove, I'm shoveling ash and coals out of it on a frequent basis during periods of continuous burning. I've read that most fires associated with wood stoves occur from improper disposal of ashes (more likely, ash with coals mixed in). If the Ideal ash pan system screens the ash that falls into it such that large coals are kept out, in theory, this makes ash disposal a bit safer. Certainly a better solution that shoveling ash and coals into a metal bucket at 5:00 every day and having to dump it when it's bitter cold out.
    fox9988 likes this.
  5. charlie
    charlie
    Schoharie, NY
    My PH just gives you fine ash in the pan...I was a happy camper to see no coals are ever wasted... I simply take my pan out and dump the ash into a 5 gallon covered pail... Then once the pail is full the ashes are dumped into a 30 gallon pail where the ashes are stored until I need them for my driveway... If I'm burning heavy I go about 3-4 days , light a week before checking the pan.. Progress ashpan and wall shields 005.JPG Ash is usually even finer then this. Like powder.
    milleo likes this.
  6. Backwoods Savage
    This from Lorin at Woodstock: It looks like you could load a max. 18" length NS, and max 22" length EW.
  7. Backwoods Savage
    Welcome to the forum golf66.
    Don't know what stove you have but most stoves should work well in most cases if you watch the firebox. With us, just before the burn gets to the all coaling stage, we open the draft all the way. That takes care of the problem as opening the draft fully keeps the stove temperature up while burning down the coals.
    Another trick that Pallet Pete uses is to spread a handful of wood pellets on top of the coals and he says he gets good results from this.
    Good luck.
    Pallet Pete and BrianK like this.
  8. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Something I frequently do is scoop the grey ash one or two scoops out of the front then pull the hot forward. This mostly eliminates the coals in the ash problem. Our stove hold coals forever which is good but it can also be irritating on very cold days when I need a full fire. The solution I've come up with is to use an old tin can to pour pellets over the top of the hot coals up by the air inlet. Those suckers burn very hot and you would be amazed at how much heat they produce in a short period! What happens is because they are already small they burn down into the coals and effectively reheat the coals. It causes them to burn down faster and break them up. The pellets don't leave hardly anything behind afterwords as they are small to begin with. They also work great to fire the stove up fast because they off gas so much it's like an instant coal bed to get the stove rolling.
  9. golf66
    golf66
    Thanks for the tip. Part of the issue is that while I have an EPA tube stove, the firebox is 2.4 cubic feet....that would be enough for a lot of folks, but if there is any substantial ash buildup, it limits the amount of wood that can be loaded as I don't like to bang the tubes or load above the firebrick. I work 60 hours per week and need both a larger firebox and longer burn times. I've seen some posts that the Ideal has a firebox of 3 cubic feet, and some of the videos showing 16 hour+ burns are just nutty :thumbs:. While an increase of .5 cubic feet on the firebox may not sound like much, if you run the numbers, it is actually 20% larger than the current setup. My wood is pretty good, a mix of 3-year C/S/S ash, hickory and oak that's reading 9-13 on the outside and mid-high teens on the inside. Not to beat a dead horse on the ash pan thing, but my little guy is pretty sensitive to dust and the Ideal ash pan system seems like it would help cut down on airborne dust that inevitably results from shoveling. As for the looks of the Ideal, well, it's not really a factor. I'm looking for it to produce heat, not win a beauty contest. Just hope they can get this thing out into the market in time for the 2014-2015 heating season.
  10. fire_man
    fire_man
    North East MA
    This is a timely post, Charlie. I own the Progress WITHOUT the ashpan, but was considering buying one. I have heard pretty much nothing but good things about doing this.
    I did hear that there were questions if the ashpan door gasket really sealed properly, and also possibly that small coals fall through the grates so there are fewer good coals left. My goal is to reduce ash dust in the house.
    fox9988 likes this.
  11. raybonz
    raybonz Moderator
    Carver, Mass.
    Welcome to the forum! About time you made it here!
    Ray
    papadave likes this.
  12. Backwoods Savage
    I agree. Good to have you here fire_man.
  13. rdust
    rdust
    SE, Michigan
    He's been here since Dec. 5th, this is just his first post. ;)
    I agree the Dennis and Ray, it's nice to see you here. :)
  14. fire_man
    fire_man
    North East MA
    Thanks Ray and Dennis and rdust.
    Old habits are hard to break. The fire feels nice and warm on this side!
    The great posts on the ashpan really have me thinking. I might just start a new thread so I don't hijack this one!
    raybonz likes this.
  15. Machria
    Machria
    Long Island, NY
    Just go get the pan! You can thank me later. I can't even imagine owning the PH without it, it's awesome. There are no issues with the ashcan door gasket, the mechanics of how it closes are so good and tight, you could prolly get away with removing that gasket. I'm not saying to do that, just that it is that tight.
    fox9988 likes this.
  16. fox9988
    fox9988
    NW Arkansas 72717
    WS ash pan systems are great. Its a built in coal sifter. I have never had to clean out my ash pan area, been burning since the fall of 2012. In my book, dealing with the mess in the house is the worse thing about a wood stove. The WS ash system means zero ash mess in the house, that takes care of the worst part of the mess in the house problem. Now all I need to deal with are little pieces of bark, thats easy. Super clean and efficient system.
    PCRit, BrianK and Tenn Dave like this.
  17. charlie
    charlie
    Schoharie, NY
    All I can say is Woodstock figured the slots in the coal grates to the prefect size as to only let the ashes through... Maybe the slots being at a 45 degree angle stops the coals from dropping through as well... All I know is it works like a charm... Believe me, you would know if the door gasket is ever bad.. Open that ash pan door and you can start a fire with one coal in the box! You'll never look back at getting the ash pan... it's the best thing,,, it holds a weeks worth of ashes! You'll love it! I just use a 3 foot metal long handled metal hoe, hands stay outside the firebox while I rake the coals... works great...
    PCRit, milleo, raybonz and 2 others like this.
  18. fire_man
    fire_man
    North East MA
    You guys have me convinced. Charlie that picture is great, thanks.
    Machria and fox, your words of praise for the WS setup say it all - I've heard enough, done deal!:popcorn:
    fox9988, charlie and raybonz like this.
  19. raybonz
    raybonz Moderator
    Carver, Mass.
    Glad you made it Tony (that is your name right?)!
  20. DaveGunter
    DaveGunter
    Can the Ideal Steel be connected to outside air? Does the outside air feed ALL of the air that the stove uses or is it like my Englander nc30 where the outside air is only for the primary air? Is the outside air setup similar for the PH and the Ideal Steel?
