Saw bogging down
Discussion in 'Chainsaws and Power Equipment' started by creek chub, Aug 2, 2016.
  1. creek chub
    creek chub
    Va
    I was using my 290 yesterday and it started and ran fine at first. It would bog down about half way thru the cut. It revved fine if I pulled it out of the log but would bog down once I started cutting again. Any suggestions?
    Shawn Curry likes this.
  2. Shawn Curry
    Shawn Curry
    Western NY
  3. Sconnie Burner
    Sconnie Burner
    Western Wisconsin
    Check the airfilter, fuel filter or the fuel cap vent first.
    creek chub likes this.
  4. pantelis
    pantelis
    Europe
    The saw work fine when is out of the wood , and when you start cutting bogging -down ??
  5. creek chub
    creek chub
    Va
    Yes. The saw starts and revs fine.
  6. MasterMech
    Sconnie Burner is on the mark on the air filter. If the saw revs fine but seems down on power, it's likely a clogged filter. If it's stumbling or stalling out mid-cut, then it could be fuel system related. Fuel filter, line or carburetor are all possible culprits.
    cus_deluxe and creek chub like this.
  7. creek chub
    creek chub
    Va
    I did a muffler mod last winter and tuned the carb. It ran great after that. I tried to use the saw again this summer and it's like a whole new saw in a bad way
  8. MasterMech
    It could be out of tune too. Especially if you haven't messed with the carb at all after the muffler mod.
  9. Shawn Curry
    Shawn Curry
    Western NY
    Do you use ethanol gas? If so you should drain it at the end of the season and dispose of any remaining fuel. Old ethanol gas can do real bad things.
  10. creek chub
    creek chub
    Va
    I do use ethanol gas and have for 5 years. I guess that may have caught up to my saw
  11. MasterMech
    If you are running the saw frequently, I doubt e-gas is the immediate problem. But it can contribute to the decay of soft components in the fuel system.
  12. Sconnie Burner
    Sconnie Burner
    Western Wisconsin
    Probably getting the wrong mix (too rich) in the warm weather. Gotta think of it like a snowmobile...... They rip like mad at any temp below ~20°, scream like no other at 0°. Anything over 30°, especially above freezing with humidity from snow melt, they really start running rich and lose power. I'm thinking thats the case with the saw too.
  13. creek chub
    creek chub
    Va
    Small engine repair is not my strong suit. I can swap parts out but next to zero troubleshooting ability
  14. Boomstick
    Boomstick Banned
    Saratoga county ny
    I doubt it.
    The only thing that went wrong with my 290 was the carb over some 15 years had accumulated dirt and debris to where it wouldn't"tune".
    Replacement carb on Amazon for 28 bucks fixed it.
  15. pantelis
    pantelis
    Europe
    I think that you have already check the filters , lines , clutches etc , etc if all theese are good
    then dismantling the carburator include the H and L screw
    then put the carb in accetone for about 10 -15 minutes take off the carb from the accetone and spray a carb cleaner from the H and the L screw holes and see carefully if the carb cleaner come out from the small holes ( jets ) that the carb have in the metering side ( where the needle is ) and from the throtle flywheel if all is ok then asemley the carb put it on the saw and tell us if its better
    your problem is a little mysterius because the saw run good out of the woods and bogging when you start cutting
    eatonpcat and creek chub like this.
  16. pantelis
    pantelis
    Europe
    Here we have a saw that iddling and run good out of the wood and when it touch the wood start bogging and make problems
    i agree to change the carb if it make the same problems in and out of the woods
    but here we dont have see yet if is the carb or something else
    clemsonfor and creek chub like this.
  17. clemsonfor
    I thought this as soon as I read it and then when I saw he tuned it in the winter I am more wondering if this is the case?
    pantelis likes this.
  18. clemsonfor
    Bogging in the middle of the cut like he says is more mysterious to me?
  19. creek chub
    creek chub
    Va
    I haven't had a chance to try to tune the saw yet. I did get a new fuel and filter and spark plug. The air filter was really dirty and the spark plug was very black. Hope to get to play with it some next Saturday
  20. clemsonfor
    Plug was probably so dirty from running rich from air restriction.
    Could also have a coil problem? Cool spark?
