029 super
Discussion in 'Chainsaws and Power Equipment' started by NBourque, Jul 28, 2016.
  1. NBourque
    NBourque
    Hey guys. I just picked up 2 029 supers the other day. One runs great the other won't start. The previous owner said it gets spark and he replaced the fuel line which had a crack in it. I pulled the muffler off to check the piston and there are a couple score marks but it doesn't look terrible. The 029 that does run feels like it has way more compression than the one that doesn't when you pull the cord. I got both these saws for $200 and I'm considering fixing the non running saw and selling it. Is there any way to tell if the piston is junk and has no compression? Also any idea how old these saws are? Thanks.
    Barcroftb likes this.
  2. Barcroftb
    Barcroftb
    The Mitten
    A compression tester will tell you if the saw is healthy or not. Something like this one will do the trick for not a lot of :makeitrain"
    OTC makes a nice one too. Alternatively you can post a pic of the scored piston and let some of the skilled saw surgeons on here weigh in on wheather it's smoked or not. What about keeping the non runner for parts?
    pantelis likes this.
  3. cnice_37
    cnice_37
    Pour a little mix down the plug hole and try to run it. If it runs for a couple seconds, then you have a fuel delivery issue.
    If compression is noticeably bad by the arm test, you might need to dig deeper and pull the jug.
    Barcroftb and pantelis like this.
  4. NBourque
    NBourque
    Here's a pic of the piston. There's a score on the right and left side in the pic. It looks like there is a score in the middle but that's just the glare.
  5. NBourque
    NBourque
    It doesn't look too bad IMO but I need your opinions.
  6. dougand3
    dougand3
    North Alabama
    That piston looks real good. Does the ring look good?
  7. NBourque
    NBourque
    Didn't really look at the ring. Like I said in my original post the saw that doesn't run doesn't quite have the recoil like the saw that runs fine. I'm not sure if it is a fair comparison.
  8. pantelis
    pantelis
    Europe
    from what the picture show the piston looks good at least for starting the saw , now you must check the rings and the cylinder also
    good compression is a result of three parts cylinder + piston + rings for sure a good compression tester will help but if you dont have one then do this
    go and buy just a new piston ring and put it inside the cylinder then measure the gap of the ends of the ring , if this gap is from 1 mm and over you need new cylinder ,
    if this gap is lower from 1mm then the cylinder is good as much close is the gap as more good is the cylinder
  9. NBourque
    NBourque
    Thanks for the info guys. Not sure I wanna tear into the saw that much. I may try the simple things first.
  10. Barcroftb
    Barcroftb
    The Mitten
    Good plan. Piston looks good. Check the ring/s and see how they look. If they look as good as the piston, compression should be fine. A saw has to have pretty low comp for that to make it not run.
    Since the piston looks good, I'm betting this is a weak spark/bad coil or fuel delivery/carb issue.
    I'd do what cnice_37 said and dribble a little fuel mix in the spark plug hole or into the carb and see if it at least tries to start that way.
    I'd also confirm for myself that it has good spark. Spark should be fat and bright blue. If it's white or seems weak the coil or plug is probably bad.
    Kyle Mulligan likes this.
  11. NBourque
    NBourque
    How can you tell if the ring is good? Can you tell when you take the muffler off?
  12. Barcroftb
    Barcroftb
    The Mitten
    Yes...... Crank it until you can see the piston through the exhaust port with the muffler off. The ring or rings, i dont remember if the 029 had 1 or 2, will be near the top of the piston. If the ring/s looks nice and smooth like the piston does then it's probably fine.
  13. NBourque
    NBourque
    Any idea on the age of the saws?
  14. NBourque
    NBourque
    So just had the saw tested for compression at the local shop. Only 90 psi. Looks like it'll just be a parts saw.
  15. dougand3
    dougand3
    North Alabama
    You could put a 49mm bore 039 top end on it. Can get just the top end or a whole short block. AM prices are low.
  16. NBourque
    NBourque
    Well the thing is after I put all this money into it how much will the saw be worth? Personally I won't need it.
  17. cnice_37
    cnice_37
    An 029 will fetch 2 bills all day long. Not from me, but they look clean. Sell it for $50 as is and buy some beer.
    pantelis and Barcroftb like this.
  18. cnice_37
    cnice_37
    Another thing before you give up, check if the ring(s) are stuck. Simple thin flat head screwdriver through the exhaust port.
  19. Barcroftb
    Barcroftb
    The Mitten
    Shoot an aftermarket 49mm 039 piston and cylinder are between 40 and 50 bucks on fleabay.
    49MM Cylinder Piston Rebuild Kits for STIHL 029 039 MS290 MS390 MS310 Chainsaw
    It's a direct bolt on. Those saws look like low hours units I bet crank and bearings are fine.
    Send it my way I'd happily pay you 50 bucks for it and rebuild it. It's probaby not worth much more than that as a parts saw.
  20. NBourque
    NBourque
    Easy to install? I have no experience with engine internals.
