Muff mod advice
Discussion in 'Chainsaws and Power Equipment' started by creek chub, Jul 15, 2016.
  1. creek chub
    creek chub
    Va
    I'm not too mechanically inclined but attempted a muffler mod on my 290 farm boss last winter.
    At first there was a noticeable difference in power and throttle response. It ran really well last winter.
    Now I started cutting again a month or two ago but it seems to bog down when it's under minimal loads. The chain is always sharp. Any ideas on what to check besides the plug?
  2. Redfin
    Redfin
    central Pa
    Have you tried tuning the saw?
  3. Boomstick
    Boomstick Banned
    Saratoga county ny
    Did you tune carb? You could try retuning it.
    You could just be used to the new or now same old power it is making. I know on my 290 it made a good difference then I got used to it until I used another stock 290 it was night and day.
  4. creek chub
    creek chub
    Va
    I've attempted adjusting the carb. I've got it where it starts four stroking when held wide open, that's what I read to do. But when I attempt to sink the bar into wood it is unimpressive. Actually it worked better before the mod as of late
    clemsonfor likes this.
  5. Redfin
    Redfin
    central Pa
    Did you retune in the winter after the muff mod?
  6. creek chub
    creek chub
    Va
    Yes. It ran really great this past winter. Guess that's why I'm puzzled
  7. Redfin
    Redfin
    central Pa
    Do you have good compression?
  8. creek chub
    creek chub
    Va
    Good question. I don't have a gauge but will give it a guess
    clemsonfor, Eric VW and Barcroftb like this.
  9. CoreyB
    CoreyB
    South east iowa
    Did you rinse the muffler real good after the mod to make sure you got all the metal shavings out. If not it could of suck shavings in to the cylinder.
    clemsonfor, Nixon, Eric VW and 4 others like this.
  10. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Sounds like it needs tuned, to do this you really need a tach.... establish your rpm, then tune the 4 stroking.....
  11. Redfin
    Redfin
    central Pa
    I bought a tach and rarely ever use it. I do on occasion check with the tach to see how high a saw is tuned after porting.
  12. Barcroftb
    Barcroftb
    The Mitten
    If I had to guess, and without the saw in front of me thats all it is, I would say it's a tuning issue. There is a really good tutorial here on how to tune a saw carb:
    Saw Carb Tuning
  13. Barcroftb
    Barcroftb
    The Mitten
    Pull the muffler and if the piston looks anything like this:
    Your piston is shot.
  14. saskwoodburner
    saskwoodburner
    Another vote for needs a slight tune up. You mentioned it's unimpressive with the tune. Is it possible that you're on the "fat" side of rich? I know from tinkering with my saw for fun, that if it 4 strokes with no load, and is still 4 stroking constantly under load (cutting), it's too rich, and loses power.
    I usually have my saw set about as rich as possible, and it just bounces in and out of 4 stroking.
    I think bobdog has a video of a little chinese saw where the tune is a touch rich, and bounces in and out under load. If you can find that tune, and lean it out a hair, you would be right on the money in my opinion.
    clemsonfor and creek chub like this.
  15. creek chub
    creek chub
    Va
    Thanks for all the suggestions. I will give them a try
  16. saskwoodburner
    saskwoodburner
    I looked back on bobdogs posts, and found the video I mentioned.
    You can hear kind of a bounce between 4 stroking and cleaning up. Often my saw is tuned like this on a full tank, and it cleans right up after 5 minutes of cutting.
    clemsonfor, bobdog2o02 and Eric VW like this.
  17. creek chub
    creek chub
    Va
    Thanks . Mine might be too rich
  18. radio
    radio
    SoNH
    If you tuned in the winter cold then in the summer heat you will be running rich. It's normal to re-tune each winter and summer seasons.
  19. clemsonfor
    I too think it's tune. And I second those that say if you tuned in winter it's possibly too rich in the summer.
    I had a cheap Chinese saw I tuned in the winter. Ran and idled fine then when it was 90F it would idle and slow and slow till ot cut off. Turns out it was loading up with fuel and flooding at idle. A slight adjustment of the L screw in this case and it's was back to running perfect. Was just the 30f difference in temp and humidity difference causeD a bad tune
  20. pantelis
    pantelis
    Europe
    I cant believe how much lucky i am , i never have touch theese screws , and for a mysterioys reasons that i can not explain never have problem with my saws
    who knows maybe here in Greece the weather and temperatures are more good for the saws
