Sharpening Thread
Discussion in 'Chainsaws and Power Equipment' started by mdavlee, Jan 27, 2014.
  1. mdavlee
    mdavlee
    I didn't know if there was any interest over here for chain sharpening. Here's some pictures of sharp cutters and the filing vise I got from homelite410 on AS.
    There's a square ground cutter
    square filed
    square filed again
    Filing vise
    round filed cutter
  2. mdavlee
    mdavlee
    I mostly use save edge round files and bahco chisel bit files from auto tool world. They have them the cheapest of any one.
  3. HittinSteel
    HittinSteel
    Wooster, Ohio
    What do you use to set the raker height?
  4. mdavlee
    mdavlee
    Mostly eye ball. I have an oregon gauge that rides on 2 cutters and the raker pokes out of it and you file it flat with the gauge. They say the file-o-plate works better but I've not tried one. A digital angle finder works pretty good also. Depending on the saw 5-6° works good.
    Pallet Pete and Hedgerow like this.
  5. MasterMech
    This thread has "Sticky" potential....... (or at least it will contribute content).
    I still want to do a chain encyclopedia of sorts for here. Strapped for time currently but glad to see there is interest in the subject, Chain mods are cheap performance! ;)
    clemsonfor, Chvymn99, fox9988 and 4 others like this.
  6. mdavlee
    mdavlee
    I'll try to get some pictures of semi chisel to go along with those.
    Chvymn99, Pallet Pete and MasterMech like this.
  7. Hedgerow
    Hedgerow
    SW Missouri
    The Husky roller guide has a progressive raker gauge that has worked well for me, because it drops as the tooth is removed, as opposed to just 25 or 30 thou below cutter height..
    Nixon and mdavlee like this.
  8. mdavlee
    mdavlee
    I forgot about it.
  9. Oliver1655
    Oliver1655
    Central Missouri
    Hedge, I hope you will be able to take some time to educate me more on your sharpening techniques the next time we do a charity cut.
    Hinerman and mdavlee like this.
  10. nate
    nate Banned
    Palmer, AK
    I'm not even sure I own a round file! I sharpen all my stuff on the grinder.
    greendohn and mdavlee like this.
  11. Hedgerow
    Hedgerow
    SW Missouri
    All we gotta do is get a couple of volunteers to run our splitters while we drink coffee and talk chain...
    :axe: :whistle:
  12. Hedgerow
    Hedgerow
    SW Missouri
    If ya know how to use it, they can do a great job too!!!
    The key is to know what you're doing, and WHY you do it...
    I'll bet mike could sharpen a chain with a snag grinder..
    MasterMech likes this.
  13. Oliver1655
    Oliver1655
    Central Missouri
    Shucks Hedge, I bet we would have folks just jumping out of the grass for the pleasure of using our splitters. :drool: I think I will stick to a cola, never was a coffee drinker. Matter of fact, I'm sure there will be an extra can or case in case you want one or two. :drunk:
    Hedgerow and mdavlee like this.
  14. mdavlee
    mdavlee
    Files are a consumable item. If they're dull toss them and grab another.
    Hedgerow likes this.
  15. bogydave
    Great pictures !
    Hand filing sharpens better ;)
    Made a vice/ bench top for sharpening. Top clamps to workbench.
    I leave the same chain on till it's done
    (unless when out cutting it hit something.)
    After each cord +/-, I clean & file, ready for next trip .
    Been using Stih RS,
    Next year trying Oregon LGX (when the RS is used up.)
    Of the 2, I think the RS holds an edge better.
    Old vs New
  16. Hedgerow
    Hedgerow
    SW Missouri
    Amen to that... If there's one thing I can't stand, it's a dull file...
    From my experience, the RS has a thicker chrome plate on top, thus making it hold an edge better,
    But.......
    I can make LGX and LPX cut faster... And they're easier on your files.
    For the exact same reason...
    I'm happy to use any of them... Just really don't like the Vanguard chain... Very not happy with it right now...
    Those goofy rakers just suck...
    :mad:
    mdavlee likes this.
  17. mdavlee
    mdavlee
    Dull file, knife, chain, or any cutting utensil. I've stopped and changed chains after a face cut with a real grabby one also.
    Oregon is good if you're going to square file. That chrome is hard on files with the stihl chain.
  18. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Hmm I'll make a video for this thread with my bench grinder. I suck at hand filing!
    HDRock and Chvymn99 like this.
  19. mdavlee
    mdavlee
    Here's the silvey RS II.
    Hand filing square
    greendohn and Hinerman like this.
  20. WeldrDave
    I have been sharping my blades on the saw with the dremel since Noah built the ark! Quick and easy! TSC, dremel, and some other places on line sell the grinding stones. Once you sharpen your blade, go back and touch the rakers and your there!:cool: Dremel even sells the sharpening kit, "which I don't use" I do everything by eyeball. I'll have to post some pic's…
