Dump trailer! need advise
Discussion in 'Chainsaws and Power Equipment' started by swags, May 2, 2015.
  1. Gasifier
    :)whistle: I am not involved.)
  2. My IS heats my home
    My IS heats my home
    Albany, NH
    Geez, with some taller sides you could probably get 3-1/2 cords in there. Thats like $750 around my way.
    clemsonfor and Gasifier like this.
  3. 94BULLITT
    94BULLITT
    Frederick County, VA
    You can get a 7x12 suretrac 12k for around $6k. A load trail is a little more.
    One thing I like about the sure trac is the frame is made from box tubing and the tongue wraps around to the front axle spring hanger.
    Load trails tongue does not extend as far back. I think the sides on dump bed on the load trail may be stronger than the sure trac but the sides on the suretrac are not weak.
    Sent from my SPH-L710 using Tapatalk
    Gasifier and My IS heats my home like this.
  4. 94BULLITT
    94BULLITT
    My suretrac dealer told me they are a good company to deal with if you sell a lot of trailers. If you don't sell many you don't get good pricing. The local dealer here was over $1,000 more than the dealer I dealt with.
    Also the adjustable coupler and the 7k drop leg jack are good option to get. The 7k jack lifts the trailer easily. The sure tracs have a lot of standard features that are options on other trailers, ramps, combo gate, board gusset kit, dual cylinders and LED lights.
  5. Butcher
    Butcher
    Hinerman likes this.
  6. swags
    swags Moderator
    I grew up in construction then got my real estate license 6 years ago. I did that to learn the real estate end of things so that i could do the flips full time. I still sell a bit of real estate but mostly flips.
    Gasifier likes this.
  7. clemsonfor
    Ok so you were an angent. I saw references to showings but was just assuming those were maybe your own properties.
    swags likes this.
