Proper water heater temperature?
Discussion in 'The DIY Room' started by basod, Jun 22, 2016.
  1. basod
    basod
    Mount Cheaha AL
    So I was doing annual maintenance on checking well receiver and replaced a barbed elbow that was weeping at the well head - fix something break something...damm you Murphy
    well pressure gauge stuck at 38psi, went to press the Schrader test valve in adjacent port and of course it wouldn't reseat.
    So new gauge and I plugged the Schrader test port.
    Decided to flush the bottom of water heater and a light brown funk was coming out with the water.
    After returning from town it had settled and is definitely some bacteria growth.
    It has been set to the economy mode ~117-119F, but I remember seeing something about preventing bacteria growth at 130F
    water heater has been installed less than a year
  2. ironpony
    ironpony
    Mid Ohio
    i believe it is 120 so no one gets scalded by accident, not sure about the bacteria growth
    Stihl Livin and yooperdave like this.
  3. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Ummm,, I run mine at 135, I like hot water. Scalds, get a mixing valve?
  4. Eric VW
    Flushed mine 2 years ago....some scale, no bacteria...set at 125 F's...town water.
  5. DaveGunter
    DaveGunter
    160 with a mixing valve set to deliver 115. The heater is a heat pump, loooong recovery, 80G tank and high set point gives you more effective capacity to deal with the long recovery time. The tank is super insulated. Plumb in a 2 foot drop off the outlet to avoid excessive heat siphoning.
    Eric VW likes this.
  6. ironpony
    ironpony
    Mid Ohio
    the reasoning behind the temp is children/ older people do not get burnt. it actually is code.
    basod likes this.
  7. bushpilot
    bushpilot
    Eastern Washington
    120 works fine for both scald prevention and preventing bacterial growth, IIRC.
    Stihl Livin and basod like this.
  8. fox9988
    fox9988
    NW Arkansas 72717
    I set mine at 120F. The lower the temp, the more efficient. I've never had a scale or bacteria problem. Well water, like God intended.
    papadave likes this.
  9. Highbeam
    Highbeam
    Why do you think it is bacteria growth? This is well water and that tank is a huge settling tank for all kinds of junk to fall out of the water while it waits for you to use it. I would always expect, even on city water, schmuck on the bottom of the tank. Sediment, iron, manganese, etc. Not likely to be any kind of bacteria in 120 degree water.
  10. basod
    basod
    Mount Cheaha AL
    Mainly believe it is iron fixing bacteria that may be lurking in the well.
    Like I said during flushing water was cloudy then after run to town I came back and instead of sediment in the bucket it looked more like a slime suspended in the bottom 2"
  11. milleo
    milleo
    When I had my old well point and alot of iron then was actually alot of "black slime" I didn't know until I got my artesian well and they flushed out the old pipes with chlorine...It was almost like black gooey tar but a little less gooey....
    basod likes this.
  12. milleo
    milleo
    PS...I drank that water all along and didn't die or even get sick...:thumbs:
    papadave and bobdog2o02 like this.
  13. basod
    basod
    Mount Cheaha AL
    yeah me neither
    Iron fixing bacteria can't survive acid conditions or caustic with bleach
    milleo likes this.
  14. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I think she meant without treatment....
