New wood storage. What do you think?
Discussion in 'The Wood Pile' started by CoreyB, Jun 28, 2016.
  1. CoreyB
    CoreyB
    South east iowa
    Well I wanted to share a photo but can not get my Internet to up load any.
    Had some extra old cattle panels.
    I took one and laid it on top of some elm logs to create air space below them one panel on each side. Drove some fence posts and will stand a pallet on each end. After it is full I will throw a cover on it. Lol not the prettiest buthe I got a lot of wood to get down and seasoned.
    Jack Straw, Horkn, HDRock and 7 others like this.
  2. papadave
    Nice idea and great pics.
    Oh, wait..........:whistle:
    Horkn, UncleJoe, Thor and 5 others like this.
  3. scavenger
    scavenger
    saybrook township ohio
    what is a cattle panel? like a lumber pallet? how big?
    Horkn likes this.
  4. CoreyB
    CoreyB
    South east iowa
    Lol finally I still have to put the pallets on the ends once it is loaded a little more. A cattle panel is 16' x 5'
    Jack Straw, TripleF, Horkn and 6 others like this.
  5. yooperdave
    Pallets for the bottom and panel for the ends, maybe.....
    No matter, the cows aren't going to use it anymore anyway!
    Horkn, Barcroftb, Thor and 3 others like this.
  6. milleo
    milleo
    If you stack it you will be able to fit alot more in that setup...:)
    Horkn, Shawn Curry, Sean and 6 others like this.
  7. UncleJoe
    UncleJoe
    SC Pa
    Maybe split it a tad smaller as well. :)
  8. Backwoods Savage
    I really like the idea CoreyB but for sure I would stack the wood for 2 reasons. It will dry much, much better and you will be able to get more into one bin this way.
    Horkn, Shawn Curry, Sean and 5 others like this.
  9. Eric VW
    Posts 5-8 are hereby awarded a :yes:
    Horkn, Shawn Curry, Barcroftb and 2 others like this.
  10. CoreyB
    CoreyB
    South east iowa
    It will dry better stacked? Here is was thinking it would have more air space and dry better just tossed in. Thanks for the info. Luckily this is 2017-2018 wood. I have a ton of dead standing so I should be able to get enough wood for the next 4-5 winters. Unless the coffee business keeps picking up.
    Horkn, Thor, Backwoods Savage and 3 others like this.
  11. Shawn Curry
    Shawn Curry
    Western NY
    Up off the ground helps a lot, but wood dries from the outside, so you really want to split it smaller than that if you want it to dry out - plus oak don't give up its moisture too easy. Even when its standing dead, the trunk will still be really wet. The tops could be pretty dry though, I'd set those aside to burn first if you can.
    Horkn, Thor, Backwoods Savage and 4 others like this.
  12. Backwoods Savage
    Yes it is true that wood will dry much faster and better being stacked rather than in a heap. Many have found out the hard way.
    Horkn, Barcroftb, CoreyB and 4 others like this.
  13. yooperdave
    ....and many are still learning!
    (and then there are those that will never learn!)
  14. Barcroftb
    Barcroftb
    The Mitten
    Nah just needs more draft!:whistle::zip:
  15. Horkn
    And more cowbell! I mean chimney!:rofl: :lol:
