Deck stair repair/replace
Discussion in 'The DIY Room' started by papadave, Jun 26, 2016.
  1. papadave
    So, the PO of this place had some stairs on this deck, and rain/chipmunks and whatever undercut any support. One of the stairs broke.
    What I'd like some advice on is how to best support whatever new steps I put in.
    Here's a pic of what's left. I can get better pics.
  2. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    How about some packed crushed stone for a base and pour a small concrete pad/landing?
    Eric VW and Jack Straw like this.
  3. ironpony
    ironpony
    Mid Ohio
    cut new stringers and lay in place, excavate about 8 inches deep at bottom step and pour concrete as Jon suggested.
    Eric VW likes this.
  4. Eric VW
  5. papadave
    Ok, kinda what I was thinking with the base. Shouldn't need stringers, as I think it's less than a foot to grade from the deck.
    Might just use a gravel bed.
    Eric VW likes this.
  6. Woodwidow
    I like the cement pad idea. It will never rot or become uneven.
    Eric VW and campinspecter like this.
  7. ironpony
    ironpony
    Mid Ohio
    less than a foot......form it up so the step is 7.5 inches, fill base with gravel, and pour a little slab
    few bags of quickcrete and done
    will711 and Eric VW like this.
  8. papadave
    This is a temp fix, but I filled about leveled, tamped the dirt, then about 4" with gravel also tamped down. This shows the original setup.
    Had some bricks that I put in the gravel, then laid a different slab on top.
    I'm still contemplating forming up for a small pour.
  9. papadave
    One of the bricks that's under the slab. The bottom slab will probably come out and I'll just backfill with more gravel or dirt.
    milleo, Eric VW, Chvymn99 and 2 others like this.
  10. papadave
    Looking at this some more......I might pull those steps (a 10" piece broke off the small one), and backfill enough to just put 'em both back down level with each other. That would leave about a 7-7.5" rise.....perfect.
    Eric VW likes this.
  11. fishingpol
    fishingpol
    Is that limestone?
    Eric VW likes this.
  12. papadave
    I believe so, Jon.
    50" long X 10" wide X 2.25" thick. Bery hebby.
    Eric VW likes this.
  13. fishingpol
    fishingpol
    Sure looks like it. They like to crack if not supported well.
    Heavy is right, I have a patio made from salvaged limestone treads.
    Eric VW and papadave like this.
  14. Eric VW
    papadave, I was wondering what they paid you as a young chap to make them bricks.....per brick or on the hour?
    :whistle:
    :BrianK:
    papadave likes this.
  15. papadave
    You funny guy, Eric. :BrianK:
    I'm too old to remember. :D
    eatonpcat and Eric VW like this.
