Operation "Tulip Poplar" is underway
Discussion in 'The Wood Pile' started by mike bayerl, Jun 19, 2016.
  1. mike bayerl
    mike bayerl
    I finally got around to working on the tulip trees that fell this spring. After much hemming and hawing, I finally decided that I would try to save the good bits for saw logs, which will leave me with at least 1/2 - 1 cord of firewood anyways.
    [​IMG][​IMG] [​IMG]
    Pallet Pete, basod, Sean and 20 others like this.
  2. mike bayerl
    mike bayerl
    BTW, you can see that I'm working top down getting the saw logs out. They will only get better as I go.:D It's taking extra time, since I'm having to play "pick up sticks" with this mess.
    Drvn4wood, Gasifier, HDRock and 5 others like this.
  3. Mag Craft
    I like those nice straight pieces you got there. Will still make some good shoulder wood if firewood is what you want. Out here I would burn it all winter long, but we just do no have a lot of good hard wood here. Like the tractor too.
    Drvn4wood, HDRock, Horkn and 3 others like this.
  4. mike bayerl
    mike bayerl
    I like tulip as firewood. It dries fast and burns nicely. However, I've got plenty of shoulder wood and I'm starting to get ahead on hardwoods like oak and black birch, so I don't need a ton of poplar. Hence, I think I'll be better off sawing the primo stuff into lumber and C/S/S the leftovers.
    Drvn4wood, Gasifier, HDRock and 7 others like this.
  5. bogydave
    Prime lumber there, dries fast & straight
    All of Dad's sawmill sheds in WV were all mostly poplar, keep it dry, lasts a long long time
  6. Splitsnstacks
    Splitsnstacks
    Sw pa
    Good stuff, Mike. I'm not a huge fan of tulip as firewood only because I absolutely cannot keep it dry. But as lumber I love it! It's one of the easiest woods to route and make nice smooth flawless looking trim, and it paints beautifully.
  7. Backwoods Savage
    For sure yellow, or tulip poplar makes some good lumber. Good on you for keeping it.
  8. mike bayerl
    mike bayerl
    Now I need to find a portable sawyer. I had a great one, but he retired a couple years ago. Anyone know a sawyer near 17078? Woodmizer site and YellowPages gave me a couple of leads, but nothing firm yet.
  9. Fanatical1
    Fanatical1
    Nice Mike! I'm a fan of the lumber, but lesser for the firewood... Dries straight for the most part.
  10. mike bayerl
    mike bayerl
    Poplar + a sharp chain, sure makes a chainsaw look impressive! Very satisfying.
  11. Minnesota Marty
    Minnesota Marty
    Eastern Minnesota
    Mike,
    At my old place I had some poplar, like yours and i made wainscotting paneling out of it..... BEAUTIFUL material.
  12. mike bayerl
    mike bayerl
    Day 2: I put a couple hours in, mostly clearing out the firewood grade stuff.
    [​IMG] [​IMG]
    I did pull few more saw logs out (the three on the right). Unfortunately, the big one turns out to be junk, so it's going into the firewood pile.
    Tomorrow, I should be able to get the primo saw logs out.
    basod, papadave, Thor and 9 others like this.
  13. HDRock
    Those logs are going to make some good lumber, in The Leftovers what makes a good Heat,
    Those popular sure do grow nice and Tall don't they
  14. fuelrod
    fuelrod
    Western Maine
    TP is generally under rated imho. Make great vertical barn siding (air on both sides), stains up real purdy and is very stable for furniture. I'd cut them all into 1" planks & sticker them under tin for future projects.
  15. mike bayerl
    mike bayerl
    I got the last of the saw logs out and started bucking the firewood.
    [​IMG] [​IMG] [​IMG]
    basod, Drvn4wood, HDRock and 8 others like this.
  16. Splitsnstacks
    Splitsnstacks
    Sw pa
    That's gonna make some perty stacks Mike :thumbs: nice and straight, will probably split quite easy!
  17. mike bayerl
    mike bayerl
    Made an appt with a local Woodmizer operator for 2 weeks from Sat. Don't expect many "action" shots, he works very quickly.
  18. mike bayerl
    mike bayerl
    Sorry for the confusion Splitsnstacks . The long, straight ones will be sawn into lumber, except for the big one in the middle. I originally put it with the saw logs, but then noticed it was partially rotten, so I bucked it up for firewood.
  19. Shawn Curry
    Shawn Curry
    Western NY
    Those are some beautiful logs Mike! :drool: I'm drooling over the tractor too..
    Ill get the popcorn ready.... :popcorn::thumbs:
  20. Gasifier
    Nice work Mike. Looking forward to seeing some boards out of them.:popcorn:
