Unfamiliar territory..... MasterMech uses a nail gun...
Discussion in 'The DIY Room' started by MasterMech, Jun 13, 2016.
  1. MasterMech
    So SWMBO has decreed that our water is to bad to ignore any longer and declared a new water conditioning system should be installed.
    My old system was installed in a goofy insulated plywood box enclosure that became a mold factory every summer as the system condensated with zero ventilation. And after a pump replacement/upgrade last spring, I've noticed that the cycle time for the pump is pretty short. To make a long story longer, I decided in addition to simply replacing my defunct water softener, the entire system and the mechanical room needed to be addressed.
    So here we go.
    The top is already off the box in this pic but you can kind of see what we had. Things look a lot cleaner in these pics than what actually was. Originally the pressure tank, and the softener were wrapped I. Pink fiberglass insulation as an attempt to insulate them. Removing that sopping mess was fun when I discovered it a few years ago. Note that the box appears to built into the wall of the mech room. The wall was actually built around the box!
    Just one example of the corrosion happening in here.
    The box was equipped with this little heater to keep the system from freezing as my garage is insulated but not heated.
    Interesting note, that's foam rubber HVAC insulation on the main water line. All of my pipes are wrapped in the stuff which wouldn't be a bad thing as it has a higher R value and is much more expensive than the typical poly-foam insulation. Too bad it's all ruined with a healthy 5-6 layers of duct tape or I'd re-use any of it I have removed.
    Creative..... And a royal PITA to demo..... I actually disassembled much of these walls and the box and we burnt the pieces for a couple shoulder season fires.
    Hmmm, this unfortunately is the best pic I have of my water system post-demo. I temporarily hooked the water lines and electrical back up with wire nuts, electrical tape, and copper unions. I can disconnect the whole system in minutes and move it out of the way and hook it back up before the wife and kiddos get home. It's tough to see but I'm feeding the house with a garden hose right now from my pump main as I will replace the 3/4" copper line with 1" copper.
    Framing in progress on one of two new walls. I actually quite like the process, especially with my FIL's framing gun.
    Walls are up, I apologize but due to the other crap in my disaster of a garage, I couldn't get a great angle on this. But you can see the entire new section. The door is just temporarily wedged in place. Was the most out of the way place to keep it!
    Eagle eyed members will noticed that the electrical is mostly in, at least the in-wall stuff. More on that tomorrow. But this is pretty much where I'm at for now. I'm actually ready for exterior Sheetrock, then insulation and finally interior Sheetrock. But I am painfully slow at this stuff due to a combination of busy work schedule, my ocd, and just not knowing what the heck I'm doing. But I'll keep stumbling through it and posting as I go....
    milleo, Stinny, ChipsFlyin and 13 others like this.
  2. MasterMech
    This is my middle son (2yo) helping me lag down the walls. Good help he is! My oldest (4) was vacuuming the dust as I was drilling the holes.
    eatonpcat, milleo, Stinny and 17 others like this.
  3. Eric VW
    Commentary points:thumbs: :rofl: :lol:
    Work scope:thumbs:
    You and middle child.....priceless :yes:
    Eagerly awaiting more pics, story:handshake::D
  4. HDRock
    Going to be gooder when you're done :thumbs:
  5. papadave
    Looks like a nice job so far MM.
    I highly dislike plumbing, so you get extra points from me for tackling that.
  6. bassJAM
    bassJAM
    Cincinnati, OH
    Lookin good! I'm in the process of finishing my basement so I'm also either learning new things, or relearning things I haven't done in 10-15 years. It's slow going for me too, it seems I only find 3-4 hours a week to work on it.
    If you really want some power nailing fun, instead of drilling holes and driving screws through concrete look into one of these:
    Ramset TriggerShot 0.22 lb. Caliber Powder Actuated Tool-40066 - The Home Depot
    I stood in the aisle at Home Depot for a full 10 minutes looking at them and deciding if it was worth the money. Turns out it was :D
  7. papadave
    Bought one of those many years ago, and it's proven itself many times to be worth whatever I paid.
  8. MasterMech
    I've used one of those plenty of times. We use them to drive studs into steel structure (I-Beams) and such for electrical boxes and other light duty jobs. They are handy! But I wanted something with a little more beef since these walls will likely have to support some beefy shelving in the near future. Those are 3/8" wedge bolts (Think 3/8" Lag Bolt for concrete) holding that wall down. Ain't going nowhere! I was able to borrow a real rotary hammer from work too so each hole took about 10-15 seconds to drill as opposed to doing it with a cordless "hammer drill". If you have seen the "hammer" mechanism in a cordless hammer drill, you know why they are a joke.
    Stinny, Chvymn99, Eric VW and 2 others like this.
  9. chris
    Be careful with that ram set- an acquaintance lost an Eye to one of those rigs where the fastener did not penetrate and bounced back-right through the safety glasses. Glasses/ goggles saved his life though as with out them it would have gone a lot further into his noggin.
    savemoney, Chvymn99, Eric VW and 2 others like this.
  10. cnice_37
    cnice_37
    I love air power tools! Framing guns rock and good job involving the kids.
    One critique - PT on concrete, but I won't tell the building inspector.
  11. bassJAM
    bassJAM
    Cincinnati, OH
    I was imagining you using a cordless drill trying to drill through concrete! I have a corded Bosch 1/2" drive rotary/hammer drill that I use occasionally when I have to drill through concrete, but it's nothing like the $800 Bosch hammer drill I used for about 2 full weeks as a co-op installing pallet racking. That thing ruined me and makes every other hammer drill seem like a toy!
    I'm a PPE fanatic (after getting a sliver of aluminum in my eye in college using a drill press), but that Ramset gun still scares me even with with safety glasses. I've gotten in the habit of turning my head when I pull the trigger, but I guess that just leaves me temple wide open! I actually ordered a face shield last week, once it comes in I'll probably double up glasses and the shield when using that thing. I'm amazed how much force is behind "just" a .22 cartridge. I can feel it in my palm after shooting 10 or so nails in a row, that thing feels more like my .357 than any of my .22's!
  12. Highbeam
    Highbeam
    So what is the new water treatment system? Looks like you had just a water softener and grit filter before. With pex, plumbing is the easy part. I have an iron removal system and a grit filter at home. I see the new blue tanks in the pic.
  13. Canadian border VT
    great job MasterMech... how many gpm is your well? I like idea of 1 inch copper you wife will appreciate in future.. volume counts as much as pressure... my self run filter and softener.. in rental units run grit filters as it makes toilets insides last longer even on city water..
    Eric VW likes this.
  14. MasterMech
    A slightly bigger softener and an air chamber type Iron/Manganese/Hydrogen Sulfide filter.
    I'm not planning on using much, if any Pex tubing for this job. I know it's just a utility room but I don't really care for the looks of the flex tubing. I am leaning towards flex connections from the piping to the softener and filter units but not final on what I want to use yet. I would do Pex in the wall in a heartbeat however.
    TurboDiesel and Eric VW like this.
  15. MasterMech
    For those looking for a good hammer drill, the one I borrowed isn't all that expensive. It's the same Bosch unit you typically see in home centers for under $300.
    Eric VW likes this.
  16. MasterMech
    This is why I posted this thing. Even though I didn't think of that, it makes perfect sense. I guessing this one will be fine as the wall that was here before it was in perfect shape and there wasn't a stick of PT in it.
    Eric VW and Canadian border VT like this.
  17. Highbeam
    Highbeam
    Oh cool. An aerator iron filter. You must have a good bit of iron. Removing iron is the job of an iron filter and it will help keep your softener from gunking up. Some folks try to use a softener for iron removal which works a little bit for low iron levels.
    I selected the mang-ox filter for iron(plus mang and sulfur) which is basically solid greensand but with a chlorine side tank for backwashing since I could not eliminate the possibility that I may have iron bacteria in my non-chlorinated well water.
    Here's mine. The clear grit filter is now dark orange but none of the iron has made it past that iron filter.
    You can buy the stainless steel semi flexible, high flow, connections between the wall and your filter heads. I don't like hard piping these things.
    Eric VW and papadave like this.
  18. Highbeam
    Highbeam
    Oh and I now buy my pex in straight sticks. No saggy coils or wrestling with it. It's just like working with copper but easier and cheaper.
  19. papadave
    This.
    MUCH easier than the coils. MUCH.
  20. Scotty Overkill
    Looking good Brian! I love working with pex, my entire house is plumbed from the basement to the 2nd floor with it.....the Maniblock water manifold is a delight ......just like a circuit breaker panel but for water.
    I recently put a new water tank in (like two days before the GTG) and we used those "Shark Bite" fittings for the copper inlet and outlet lines. I was very skeptical of those fittings but after installing them, I'm now sold on them too......
