Looking for advice
Discussion in 'The DIY Room' started by papadave, Jun 12, 2016.
  1. papadave
    on a real good floor finish for a high traffic area on solid Oak.
    Brother and I ripped up some old carpet at my son's place and two steps need refinishing.
    It's been about 40 years since I last did this. I'm sure there must be better urethane or something nowadays.
    Easy to apply is a must.
    wildwest and Horkn like this.
  2. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    I used the low v.o.c. semi-gloss poly in my kitchen and I would never use it again. It dries quick and has low odor, but it seems to have more tint and less amber finish. It looked nothing like the poly that I put down 10 years ago when I redid the floors.
    As far as new products, I can't help. I just use the tried and true.
    Horkn and papadave like this.
  3. papadave
    Thanks Jon. I've used both oil and water based on other projects, and prefer the water based.
  4. mywaynow
    mywaynow
    I used oil semigloss over clear 20 years ago. Dogs, kids and me abusing the floor and it looks great today. Not perfect, but real good.
    papadave likes this.
  5. brenndatomu
  6. mywaynow
    mywaynow
    My application was gloss first coat or two, than satin over. Depth with the advantage of non gloss finish.
    papadave and brenndatomu like this.
  7. jtaves85mcss
    jtaves85mcss
    SW Ohio
    Depending on adjacent steps and the exact look you are going for... Real depth and the look of an old field finished floor can be duplicated by cleaning well (denatured alcohol) then applying a couple of light coats of rubbed boiled linseed oil, each wiped off after a 30 minute wait. It will darken the floor a shade or two. Let it dry two days (you can walk on it gently) then give it one light coat of a oil based semigloss poly. If it dries quickly, give it another that same day, otherwise wait, then add another the next day. That boiled oil will give you a look not to be missed.
    If the overall floor has some 'character' just use the semigloss oil based poly.
