Looking for a new saw recommendation.
Discussion in 'Chainsaws and Power Equipment' started by streem26, May 16, 2016.
  1. streem26
    streem26
    Vancouver
    Hi everyone ! Im new on forum and same think which chainsaw should buy !The trees I am taking down are around 16" -19" in diameter. I want a saw that can be used next year and those that follow for a long time and thus it should be budget. Is it possible? I want something that will get through the wood reliably, smoothly, and quickly. I'm thinking a saw with a 18" bar, or should I be thing 20"? After this reviews choose between Husqvarna 455 and chiper Poulan Pro
    wildwest and HDRock like this.
  2. clemsonfor
    I would start a new post with this question . I bet a mod will create one for you so you will get more people looking at your question.
    I think I would consider Echo as well, there a very good saw for the money.
  3. fezdawg12
    fezdawg12
    Elko, Nevada
    Welcome.
    I agree with Clem that an Echo would be a good choice. CS-490 would suffice but the 590 is a better value. Husqvarna 455 is a little more saw than the 490 but smaller than the 590 at about the same price.
    What is your budget?
  4. CoreyB
    CoreyB
    South east iowa
    I am going to jump on the band wagon.
    Echo 590.
    Eric VW, Barcroftb and wildwest like this.
  5. wildwest
    Nice to meet you:)
    Eric VW and Barcroftb like this.
  6. RCBS
    What reason are you felling the trees? Are you clearing land or just for firewood use? Is the weight of the saw a factor?
    I would agree that the Echo line is going to be the best value short of picking up a low hour used unit. Are there dealers near you? Something to consider if you will be using the saw/s indefinitely.
    Welcome to the forum. Good folks here.
    Eric VW, Barcroftb, CTYank and 2 others like this.
  7. Frank and Beans
    Frank and Beans
    Those are decent sized trees you are cutting. I would think you would want something in the 60cc range. Maybe a Stihl MS 362 with a 20" bar. I wouldn't be afraid to buy a used one, you will be able to tell if it has been taken care of. You will get many different opinions on what saw to buy. Many of the box store saws are disposable. They are not made to be repaired and don't last long. If you are able to find a good dealer it will help a lot. I believe in spending a little more and buying a good quality tool that will last a long time, but I learned this the hard way. Have fun searching and best of luck.
  8. CTYank
    CTYank
    CT Panhandle
    If you're looking in the 60 cc range, the Echo 590 already mentioned is the bargain unit, and the Dolmar 6100 is the performance/value unit, IMHO. Not to mention that those factories doesn't embargo IPL/manual/parts to dealer-only, or bootleg supply, so dealers can extract mo-cash.
    If you're looking to use any saw for an extended period, you really want to invest the time, thought and effort to learn how to file chains. Not for nothing is the tool called a CHAINsaw. Plenty of do-dads available there for the job, besides time-tested tools/methods. Still magic to some. Ideally you want to KEEP the chain SHARP. It's trivially simple to wreck saw-chain.
    Happy hunting!
  9. Barcroftb
    Barcroftb
    The Mitten
    A good dealer should be able to tell you how many hours are on any of the electronic carb'd Husky and Stihl saws. Makes it easy to meet the seller of the saw at the dealer to be sure it is in fact a low hour unit.:thumbs:
    As to the box store Echos they are most certainly not disposable saws. The homelites, ryobi, etc. however :whistle:
  10. DonE
    DonE
    NE GA
    For a long time I was a Stihl guy..... I have moved to the Dolmar camp these days so I'd say the 6100 would be a good choice. I don't think you can go wrong with any of the (pro) saws mentioned. DO learn to sharpen chain, cuz the biggest baddest saw still sux with a dull chain. Filling is fine and is a good skill to have, but I personally got myself a grinder. I take multiple chains for each saw to the wood. I change chains a soon as they slow down a little bit. I take the used chains and drop them in some cleaner and sharpen with the grinder the next day.
    CoreyB and Eric VW like this.
  11. Frank and Beans
    Frank and Beans
    I have heard good things about the Echo saws, no first hand experience though. Poulan and Homelite on the other hand.....
  12. tamarack
    tamarack
    paulina oregon
    Dont be afraid to lay out for a 50-60 cc pro class saw, dolmar 6100 or husky 550 or 562. I have a 550 and love it more everytime i use it.
    RCBS and CoreyB like this.
  13. CoreyB
    CoreyB
    South east iowa
    A Husky/ jred 555/ 2258 would be another I would go Jonsered over the husky for some reason seem to be less troubles but I can't stand the outboard clutch.
  14. MasterMech
    There are a couple key points when it comes to qualifying a customer and trying to match up their needs and budget to a piece of equipment.
    That 455 Rancher will do exactly what you want (reliable, smooth, and quick enough through 18" wood) and do it well for a long, long time.
    For the size of the trees you describe, a saw with either an 18" or 20" bar will do just fine. If most of the wood you cut is in that 16-19" range, I'd be looking hard at a 60cc saw. The Echo CS-590 lands right in your (presumed) $400 budget and should handle your needs.
    Barcroftb, RCBS, fordf150 and 2 others like this.
  15. fordf150
    fordf150
    Newcomerstown ,Ohio
    I didnt see a budget mentioned but that would be a big help in getting good reccomendations. New or used wasnt mentioned either......help us out with answering those 2 questions and we can give you a good list to get started looking at without wasting your time on saws that are out of your price range.
    Barcroftb, HDRock, RCBS and 1 other person like this.
  16. wildwest
    I have questions too, from a female perspective. Prefaced with I don't run dear husbands saw...... Do you burn wood for heat or will this be used as a yard maintenance tool? How much wood will you be cutting? The awesome guys here will set you with a fantastic saw for sure!! But if you don't need a big bad saw? There might be other options:) Another point, I ran a tiny saw years ago, even that got heavy for me after awhile. He has a smaller Stihl now, no way I could run that safely because of the weight for more than a couple cuts. Thought I would throw out some ideas:)
    papadave, Stinny and Barcroftb like this.
  17. MasterMech
    But but but, EVERYBODY needs a big bad saw! Right guys? Right? ..... Guys?
    :picard:
  18. Eric VW
    Right!!!
    At least 2 or 3!:saw::saw:
  19. pantelis
    pantelis
    Europe
    For someone who is not professional and use the saw for colecting some firewoods or make some work at the home yard a 50 cc pro saw is all that he need
  20. pantelis
    pantelis
    Europe
    For what reason ???
    Barcroftb, wildwest and Eric VW like this.
