Protect Your Rear End!
Discussion in 'Everything Else (off topic)' started by Greenstick, May 10, 2016.
  1. Greenstick
    Greenstick
    I want pictures ideas thoughts and wild arsed plans to protect tail lights on a trailer. I am sick of at least a couple times a year needing to replace my box lights bolted on a angle iron off the side of my trailer that are out in harms way getting smashed constantly.:mad::headbang:
    NH mountain man and Horkn like this.
  2. yooperdave
  3. papadave
    Quit backing into stuff? :D
    BTDT.
    I want the solution for trailer lights never working properly.
  4. bocefus78
    bocefus78
    I run a variation of the steel boxes pictured in the above link.
    Fwiw, get used to busted lites on a open trailer. Even with cages somebody still racks a Lens or 3 per year if the trailer gets used for daily work. Lenses are $3 each. Weld the steel box around it and buy a case of lenses. ;)
    And the solution to lights not working is a front to back rewire, with soldered and heat shrunk connections, combined with dielectric grease. Ditch the crimps, butts, and electrical tape. My crap azz trailers sit outside 24-7 365 and I don't bother checking lites......because they work and have for 10 plus years.
    Jon1270, MasterMech, Chvymn99 and 7 others like this.
  5. rottiman
    Good ground and LED lights....................
  6. HDRock
    I'm doin pretty good, couple years now only a crack in one lens .
    Check this out , One time I backed my trailer into my other trailer and broke a light on both of em :headbang::hair:
    As someone on here said , best bet , run a ground wire for each light , I might do that
  7. rottiman
    Go to using round led lights and mounting then inside a short piece of steel pipe welded to each rear corner of the trailer. They don't bend, they don't break..............................
  8. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    X10- 5" sch 40, piece of flat bar welded to the back with 3 holes, 2 for studs-the other for wires. About 6" length and you're done.
    edit- the middle picture on Yooperdave's link. Shows the pipe mount.
    NH mountain man, Horkn and Greenstick like this.
  9. Greenstick
    Greenstick
    The backing up n hitting shtuf isn't the issue. It never fails that I try to put one more log on and it falls on the light bouncing back to the road. It would happen even if I only loaded one twig on the trailer my luck is so bad. That and I swear my assistant thinks they are steps to get in the trailer. 20160510_195135.jpg
  10. bocefus78
    bocefus78
    Yup...the pic above screams "I need caged". If you can't weld, drill it and bolt it.
    Once they are caged, they ARE steps lol.
  11. Beetle-Kill
    Beetle-Kill
    Yup. Cut that angle back to about 2" from the frame and weld the pipe to it. Switch to round lights and you're golden. The angle becomes the weak link at that point.
    NH mountain man and Greenstick like this.
  12. HDRock
    Cut the brackets off , weld em on the other way , that's how mine are, angle iron covers part of the top, they were mounted on the fenders when I bought it, not visible enough there IMO so , I welded on angle iron and moved em to the back
  13. HDRock
    Would you have a side marker that way?
    Around here they will pull you over if your side marker isn't working , side markers are required
    Beetle-Kill and Greenstick like this.
  14. Beetle-Kill
    Beetle-Kill
    Good call! Reflectors suffice here. I would check that, but notching the pipe on the sides should do the trick for compliance, but I'm not certain.
    A downside to using the pipe covers is the lack of reverse-back up lighting. But...
    add a couple of LED lights activated by a toggle switch, very useful. Get someone tailgating you on the hwy., quick "blip" from the lights, no more issues.
    Chvymn99, Greenstick and HDRock like this.
  15. NH mountain man
    NH mountain man
    WMNF N.H.
    I was backing my F-150 into the driveway in a blizzard and hit the mailbox. Smashed in my taillight and destroyed the mailbox post. I was pizzed, then the wife came out to make me feel feel better by saying " what are you an idiot?":headbang::doh:
  16. papadave
    I think you get bonus points for that move, HD. :rofl: :lol:
    yooperdave, HDRock, Chvymn99 and 2 others like this.
  17. HDRock
    :rofl: :lol: Yeah, that was a smooth move :whistle: couldn't have done it if I planed it :picard:
    Greenstick, rottiman and papadave like this.
  18. MasterMech
    Incandescent trailer lighting is for suckers (these days that is, if you have 'em and they work, so be it).
    So are chassis grounds on trailers. Run a common for the critical lighting. Get good non-insulated crimp connectors and use the type of crimp tool that folds each tang into the middle or punches down the center. No half-round crimps. Then solder and shrink those connections. (This applies for electric brake wiring too!)
    As far as Murphy proofing tail lights goes, something like this is a pretty easy add-on.
    HDRock, papadave and Greenstick like this.
  19. HDRock
    Definitely going LED next time
  20. TurboDiesel
    I made mine out of steel box tubing and cut the holes in and capped the ends.
    Like this pic but heavier. I'll get a pic when possible.
