Eljer toilet
Discussion in 'The DIY Room' started by Beetle-Kill, May 4, 2016.
  1. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    I've gotta replace the guts in an older Eljer toilet tank.
    I have the stamped numbers from inside the lid, and part numbers from the flapper. But I can't find out what they relate to concerning new parts. It's probably close to 20 years old, just a guess.
    Any ideas on what I should look for to pick up new parts? Thanks, JB
    wildwest, Eric VW and Horkn like this.
  2. Grizzly Adam
    Grizzly Adam Guest
    Just get a universal kit with a built in float. About 7 bucks for a decent one.
  3. Horkn
    Get the new style with dual flush while you are at it. Universal ones are great.
    The dual flush allows less water for #1, but full flush for #2.
    Win win.
    papadave, Beetle-Kill and Eric VW like this.
  4. Beetle-Kill
    Beetle-Kill
    OK, should I strip everything out and just head to Lowes or HD and pick up compatible parts? I'm good with that, both stores are about 30 min. drive, either E or W.
    Eric VW, Horkn and bobdog2o02 like this.
  5. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Yes
  6. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    And for another 100 you get a new efficient toilet kit..... with everything.
  7. wildwest
    We put a $99 Aqua Source toilet in our colorado home before moving, it worked GREAT, flushed better than the ancient 3.5 gal toilet, and less water into the septic tank. Just a thought:)
  8. TurboDiesel
    A lot of those older toilets use way too much water and still don't flush the bowl clean.
    Parts are pretty cheap though.
  9. basod
    basod
    Mount Cheaha AL
    The flapper/flush valve won't fit many old toilets with the universal kits - just a heads up.
    Fill valves are pretty straight forward changeouts
  10. Canadian border VT
    as a landlord.. I get champion 4.. will take just about anything without clogs... 205 at HD.. it's EFFICIENCY rated
  11. TurboDiesel
    I use the same, need to add the Fluid Master/Amercan Standard Performax fill valve with the adjustable refill to fill the bowl to the proper level. The low refill allows the siphon to suck the bowl empty too fast.
    If you dont fill the bowl high enough, the siphon jet flushes the water down the bowl before the water can reach the back of the bowl at the rim. I know, this sounds crazy, but the water flows counter clockwise around the rim of the bowl and get to the siphon first. If the bowl empties out before the water reaches the back of the bowl, the bowl cant wash clean. When the bowl is filled properly, the siphon jet cant empty the bowl as fast.
    Sadly, Amercan Standard knows this but chooses to put a "cheaper" Fluid Master fill valve in at the factory. Even though they own Fluid Master now.
    Fluidmaster Performax Fill Valve-400ARHRP7 - The Home Depot
  12. wildwest
    x2, I had a heck of a time finding flapper, ball cock assy, and float for our 1960's toilet.
  13. basod
    basod
    Mount Cheaha AL
    That's where I'd probably bite the bullet and drop a new toilet in, unless you're looking to match the avocado fixtures:D
    The new one I dropped in the 1/2 bath remodel flushes like a boss, refills much fatser
  14. Canadian border VT
    exactly right! 5 minute change out so easy taught a tenant to do it.. my HD sells those in a plumbers six pack for 29.99 most people don't need six on hand but I do:picard:
    Horkn, Beetle-Kill, Eric VW and 2 others like this.
  15. TurboDiesel
    how many units you have, Cb?
  16. Eric VW
    Wow TD, you really know your sh........
    :thumbs:
    :wacky:
    Horkn, wildwest, Beetle-Kill and 2 others like this.
  17. TurboDiesel
    its like a TurboFlush now...
    I apologize in advance for this derailment :D
  18. TurboDiesel
    hang on
    I got a pic
  19. Eric VW
    Thankfully the flash cube failed, Turbo Polaroid:rofl: :lol:
    :BrianK:
    Horkn, wildwest and Beetle-Kill like this.
  20. Canadian border VT
    only got 12 units but in those 20 toilets with and personal house got 3 more:bug:.. Lowe's has kitchen fawcet.. high arch moens.. 79.99 all same now that way never have to wonder what cartridge I need .... took me 2 years of 6 different brands and styles figure that one out :emb:
    Horkn, wildwest, basod and 2 others like this.
