Question for the Stihl guysfo
Discussion in 'Chainsaws and Power Equipment' started by Smoketr1973, May 4, 2016.
  1. Smoketr1973
    Smoketr1973
    Vinemount, Ontario, Canada
    Quick question for all the Stihl fans and techs out there. I have an older 044 that I am putting back together for a fellow hoarder after a felling mishap. No personal injury's, only the rear handle/tank assembly smashed off. He is 80 and a very capable wood cutter, but starting this saw wears him out quick. My question is, during the rebuild can I swap out the cylinder for one with decompression valve and drill the top plastic to accommodate it? Any ideas would be appreciated.
  2. papadave
    :popcorn:
    Eric VW and Horkn like this.
  3. Barcroftb
    Barcroftb
    The Mitten
    I've never done it but I'm pretty sure you can put the 440 jug on there with the decomp valve.
    Eric VW, Horkn and pantelis like this.
  4. pantelis
    pantelis
    Europe
    The stihl produce the 044 with decomp valve cylinder of a little , i am not 100 sure but i think that the 440 cylinder will fit to the 044 case , 440 is with decomp valve
    Eric VW, Barcroftb and Horkn like this.
  5. pantelis
    pantelis
    Europe
  6. PA Dan
    PA Dan
    White Oak Pennsylvania
    It can definitely be done. You can also get the cover with the hole in it.
  7. Smoketr1973
    Smoketr1973
    That's great. Thanks for all the information. I'll post some pictures of the transformation once I get into it.:D
    Eric VW likes this.
  8. Jon1270
    Jon1270
    Pittsburgh, PA
    I think the decomp cylinders only became available after they switched to a 12mm wrist pin on the later 044's. If you're working on a 10mm saw, a newer 12mm cylinder will bolt right on but you'll have to check the locations of the piston ring-locating pins relative to the intake and transfer ports. My understanding is that some 12mm cylinders don't play well with 10mm pistons.
    pantelis likes this.
  9. pantelis
    pantelis
    Europe
    I dont know .......... i just say ........ create a area-place for install a decomp to the old 044 cylinder , using TIG welder fill with aluminum the fins of the cylinder and then machine work for put the decomp valve
    maybe cant be done maybe can be ................. i will try some day
    Barcroftb likes this.
  10. mdavlee
    mdavlee
    Easy enough to drill and tap a center one in the existing cylinder. It will look a little redneck in the cover but it will be cheaper.
    Barcroftb and pantelis like this.
  11. pantelis
    pantelis
    Europe
    Thanks for the Help
    Smoketr1973, Barcroftb and mdavlee like this.
