Pontoon upgrade
Discussion in 'Chainsaws and Power Equipment' started by Horkn, May 3, 2016.
  1. Horkn
    So, here's the pontoon my parents bought. It's in my driveway until it gets up north to the cottage. IMG_20160427_184816688.jpg
    20 foot, 60 HP mariner 2 stroke oil injection and power trim and tilt. 16 cup holders, Bimini, 2 tables and seats 10.
    It's nothing crazy, but we'll get really good use out of it. My dad will be able to board easy. It will be much more stable than the V hull 14' fishing boat they bought last year.
    I'm upgrading the stereo with much better speakers and Bluetooth, with a better choice than the AM FM with cassette it had. The new stereo can take a USB drive loaded with music. Or I can stream music from my phone to the head unit.
    Old puny vs new bigger
    I cut the holes bigger and installed the front 2 speakers tonight.
    There were only 2 speakers before. I'll install the back 2 speakers, the same 6.5" ones as in the front., and then put the new head unit in. I have to cut the 2 shaft old style out and then I can put the DIN front mount in.
    The view of the back. Taped up bimini from traveling.
    I ran out of light and energy today. More work on it tomorrow.
    savemoney, RCBS, bassJAM and 11 others like this.
  2. Horkn
    OK, got the stereo hooked up and going.
    I had to cut out the 2 knob stereo holder to take the DIN mount. No stitches required. I used a hack saw.
    Then the stereo all wired up as a test. With the cover up.
    Yes, the Bluetooth works well. All over the boat, and one of the 2 bigger cup holders works great as a cell phone holder.
    The front speakers work well, using the seat bases as a speaker box. The remote works from all over the boat too.
    The back speakers I just set on the floor to know they worked. I will need to cut out 2 more holes under the back bench.
    I also need to run the new wires to the front speakers. They go through, then under the deck. Should be easier on the trailer than on the water. I think I'm going to need more speaker wire.
    XXL, Barcroftb, Ashwatcher and 3 others like this.
  3. Sconnie Burner
    Sconnie Burner
    Western Wisconsin
    Looking good! Where's up north?
  4. Horkn
    Tomahawk, on Lake Mohawksin.
  5. bassJAM
    bassJAM
    Cincinnati, OH
    A good sound system is pretty darn important when you're on the water!!
    Horkn, RCBS and Barcroftb like this.
  6. Horkn
    Now I got 4 new wheel/ tire combos as all of the tires either had some sidewall trauma, and one had a bend to the rim.
    I think I'll drop the boat in the driveway, and then pull the rig forward, and change the tires. It's just too difficult to do with the boat on the trailer. Hopefully I can finish the wire routing and speaker mounting tomorrow after work.
    eatonpcat and savemoney like this.
  7. Horkn
    OK, I got the wiring done Friday night for the speakers.
    Yesterday I swapped out the tires and wheels for the new ones.
    To do that, I had to get the pontoon off of the trailer.
    Here it is on the driveway, and off off the trailer. An odd sight for someone that is used to competition ski boats. IMG_20160507_144420745.jpg
    All wheel tire combos replaced. Trailer going back under the boat to lift it off the driveway. IMG_20160507_154055329_HDR.jpg
    All done.
    eatonpcat likes this.
