Bearing Failure
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by pell it, Jan 20, 2014.
  1. pell it
    pell it
    Rhode Island
    Combustion blower decides to take a dump on one of those 8 degree and dropping nights a couple weeks back. Had a spare motor that fit.
  2. stuckinthemuck
    stuckinthemuck
    Better to be lucky than good!!... but in this case I think you had a little of both..;)
  3. imacman
    imacman
    Denver, NC
    Yep, doesn't sound good.
    Can the bearings be replaced? You'd have a good spare again.
  4. pell it
    pell it
    Rhode Island
    Looks like they can, just have to figure out how to press the cooling fan off the shaft first. It's almost like a " hot n cold" interference press fit. Does not want to budge.
  5. imacman
    imacman
    Denver, NC
    A little concentrated heat on the fan hub?
  6. pell it
    pell it
    Rhode Island
    That is what I was thinking
  7. DexterDay
    That sounds bad! Glad you got it fixed.
    Spares are always a good idea!!
    Nice fix! Good luck getting the pressed cooling fins off!! Let us know how you make out!
