Vegetable oil as bar oil
Discussion in 'Chainsaws and Power Equipment' started by Kimberly, Apr 5, 2016.
  1. Kimberly
    Kimberly
    The Kangaroo State
    My friend told me that he heard that vegetable oil could be used as bar oil. Is this true?
    XXL, thistle and Barcroftb like this.
  2. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    If you are carving a side of beef...
    I think it would be too thin for bar oil and certainly would not have any tacifiers.
  3. Barcroftb
    Barcroftb
    The Mitten
    It can be done. I have a small saw I use to cut pieces of fruit wood for my smoker that I use veg oil in. There was a huge thread over on arboristsite.com about it. If you find it be prepared for some hard core master debating!
    There are some pros and cons. As Guido Salvage mentioned no tackifiers so the oil is less likely to stick to the chain after it makes the turn around the nose of the bar. I havent noticed this issue with the 16" b&c on the saw I use. I'm not sure that it would work in long bar lengths or heavy use.
    The other main issue is that the oil if left will thicken and solidify as it ages and can cause clogs of the oiling system. Most saw makers seem to have a biodegradeable bar oil. IIRC they are mostly canola oil with added tackifiers and stabilizers.
    clemsonfor, Eric VW and Kimberly like this.
  4. bushpilot
    bushpilot
    Eastern Washington
    I believe there are veggie based oils available, but they would be specifically produced for bar oil. I wouldn't use veggie (cooking) oil, I don't think it will work that well.
    Barcroftb and Eric VW like this.
  5. bogydave
  6. Kimberly
    Kimberly
    The Kangaroo State
    I did not know that bar oil had stuff in it to make it more tacky and thus stay on the chain better.
    clemsonfor and Barcroftb like this.
  7. Nixon
    Nixon
    West Sunbury,Pa .
    As stated above , Canola oil works . Other vegetable based oil may work , but will oxidize and turn to glue on the saw . I use a mix of about 50/50 bar oil ,Canola for winter sawing . No ill efffects .
  8. ironpony
    ironpony
    Mid Ohio
    I use the oil I drain from the Cummins in the saws.......IP runs and hides......
  9. Barcroftb
    Barcroftb
    The Mitten
    Oh boy you gone and did it now! :loco: :crazy::rofl: :lol:
    clemsonfor and Kimberly like this.
  10. ironpony
    ironpony
    Mid Ohio
    I hug the tree right before I cut it down, does that count??:tree:
  11. JustWood
    JustWood Guest
    Ive used canola for a long time and it can cause problems over time. I've found mixing it with dino bar oil lessens the likelihood of issues.
    I wouldn't recommend using it below 40F either and definitely DO NOT use peanut oil. If you want to see what I mean,,, take the veggie oil out of your cupboard and leave it outside on a nite below freezing.
    OldJack, clemsonfor, papadave and 2 others like this.
  12. thistle
    thistle
    Polk/Guthrie Counties,IA
    I use soybean/salad oil for all my saws in all seasons.Can be a wee bit thin on a real hot summer afternoon but still enough remains on bar/chain to lube all the parts sufficiently.No problems using it regardless.Since I never leave gas or oil in the saws more than a few weeks without using or draining it.
    papadave, Kimberly and Barcroftb like this.
  13. saskwoodburner
    saskwoodburner
    I'm sure canola oil would work fine for your purposes as a homeowner/wood burner if you gave it a try. Now, if it was Kimberly&Co Redwood Milling Inc :D, you'd probably be better off sticking to normal bar oils.
  14. yooperdave
    Yeah, I'm another one as I have been doing this for years!
    Should resurrect that thread, huh?
    :cool:
    clemsonfor likes this.
  15. MasterMech
    Nothing good can come of this. :BrianK:
  16. thistle
    thistle
    Please don't.
    clemsonfor, Locust Post and Barcroftb like this.
  17. JustWood
    JustWood Guest
    Me too.
    I have a bio/black diesel setup.
    Finished oil goes into a final settling tank and whatever is needed gets pumped off the top to final use.
  18. XXL
    XXL
    Ontario, Canada
    We use vegetable oil in a battery operated chainsaw when quartering moose :whistle:
  19. thewoodlands
    thewoodlands
    I've used Canola Oil in my saw for over four years, the veggie oil will thicken up real good in the winter time, since I do cut some in the winter, I stay away from the veggie oil.
    Grab yourself a small bottle of either the Canola or Veggie Oil just so you can try it before buying a bigger container.
    clemsonfor, papadave, thistle and 2 others like this.
  20. yooperdave
    And a julian cutting attachment for the chain!
    eatonpcat, jon1212, papadave and 2 others like this.
