Another Cherry
Discussion in 'The Wood Pile' started by thewoodlands, Mar 27, 2016.
  1. thewoodlands
    thewoodlands
    100_9962-004.JPG Once I'm done with the Sugar Maple up the ridge from here, I'll take care of this uprooted Cherry.
    Like Locust Post said, cut from the bottom up first and then do your plunge cut :yes:, this has a chit load of pressure on it.
  2. Locust Post
    Just be careful.....I know you are but still have to say it.
  3. NH mountain man
    NH mountain man
    WMNF N.H.
    That's a good size Cherry, have fun with it. Cherry is a great wood, some years more than half of my stacks is Cherry.:stacke::saw:
  4. Frank and Beans
    Frank and Beans
    I like cherry also. Sometimes I don't think it gets the respect it deserves, but I think it is great. Splits easy, dries quickly, and burns hot. Good stuff.
  5. Backwoods Savage
    But you don't have to cut that far from the bottom up. Just a little will keep it from splitting. I also can see no reason for a plunge cut.
  6. thewoodlands
    thewoodlands
    I did part of that Cherry two years ago, if you cut it from the top down it will split before you get done, if it reacts like the Sugar Maple I did the plunge cut on, it will hold together much longer.
    Either way you'll hear a pop, a chit load of tension in that tree.
    Horkn, Well Seasoned and Ashwatcher like this.
  7. thewoodlands
    thewoodlands
    I'll have the wife come back in when I do it, she went when I did the Sugar Maple.
  8. Backwoods Savage
    Not if you undercut first. Then you don't have to plunge.
    Horkn and Well Seasoned like this.
  9. thewoodlands
    thewoodlands
    The undercut won't stop it from splitting, chit it might split with the plunge cut up.
    I did the undercut on the twin (where it split off the main trunk) and then made my cut from the top, that split down the middle because of the tension.
  10. Backwoods Savage
  11. thewoodlands
    thewoodlands
    You should see the size of the trunk before it splits, if I remember it's a pretty good size log.
    Horkn likes this.
  12. Jon1270
    Jon1270
    Pittsburgh, PA
    I can't tell from the photo -- what is holding that tree up off the ground? Is it hung up on another tree somewhere?
    Horkn likes this.
  13. thewoodlands
    thewoodlands
    It's laying on the ridge until the ridge drops off.
    Backwoods Savage and Horkn like this.
  14. thewoodlands
    thewoodlands
    Both these are down from the Sugar Maple on the same ridge, I would like to get the Cherry in picture 9987 this year.
    Picture 9988 is down the ridge from 9987, it's sitting on a broken off Maple.
