What kind of Den is this?
Discussion in 'Everything Else (off topic)' started by thewoodlands, Mar 24, 2016.
  1. thewoodlands
    thewoodlands
    I was going through these old pictures when I found this, I'm not sure where on the property it is. 100_0752.JPG
    wildwest, milleo, Horkn and 2 others like this.
  2. Eric VW
    Fox?
    Too bad there's nothing else in the pic to scale it by, unless the time/date stamp was "scalable".......
    Just be careful around it(if you stumble on its location) as the temps warm up.
    wildwest, Horkn and papadave like this.
  3. thewoodlands
    thewoodlands
    I think it's off of a secondary trail we use to ride every so often, if I'm correct it's in the area where I grabbed a downed Cherry.
    If I get time tomorrow, I'll check it out.
  4. Eric VW
    The limbs around the Den hole look a little punked so I guess you'll leave them alone?
    :thumbs:
    wildwest, Horkn and thewoodlands like this.
  5. thewoodlands
    thewoodlands
    We've had a Fox in the backyard (woods) chasing some food this year, it's the first time in three years the Fox has been around.
    wildwest, Horkn and Eric VW like this.
  6. Eric VW
    Hope you can find the location again. Could you pull back on a current shot then, so we can see what kind of tailings this mining little critter deposited in the creation of this Den? Please, Sir?:yes::)
  7. thewoodlands
    thewoodlands
    This is a Fox den I found on the net.
    wildwest, milleo, Horkn and 3 others like this.
  8. thewoodlands
    thewoodlands
    Sure will, if I'm correct on the location, it should be on a southwest facing hill.
  9. yooperdave
    Sure don't claim to be Jeremiah Johnson, but the first thing I thought of was fox, also.
    wildwest and Eric VW like this.
  10. rottiman
    Fox or maybe a fisher......................
  11. lukem
    'Squatch. For sure. Dump 100 gallons of diesel down it and set it off. Your nation will thank you.
  12. Stinny
  13. Well Seasoned
    Definitely Fox or wild boar. Whichever is normally in your area.
    wildwest and Canadian border VT like this.
  14. Eric VW
    Jeremiah Yooper, maybe.....:whistle:
    wildwest, unclefess and yooperdave like this.
  15. Backwoods Savage
    Could also be coyote.
  16. yooperdave
    Coyote could get in and out of that hole, but I think their's are larger than that one.
  17. thewoodlands
    thewoodlands
    I went for a ride to the area that I thought this was in, strike 1.
  18. Backwoods Savage
    They can surely surprise you though. I recall not that long ago we had a den behind the house. I did not think any chance of being coyote, but lo and behold, it was coyote going in and out and then out come a bunch of little coyotes too! Amazing how small that hole was.
    yooperdave and Well Seasoned like this.
