When was the last time you cleaned your stove?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by will711, Mar 24, 2016.
  1. will711
    will711
    Pocono Mts.
    With shoulder season here and stoves being on and off I was wondering has anyone else gone Slacker like me :smoke:?? Pushing 6 weeks since the last clean was hoping to hold out till the end , but the p43's ash pan is full and it is filthy :bug: pic's for proof.
  2. subsailor
    subsailor
    Winthrop, Maine
    Can't say I've ever seen my stove that dirty. Been 3 weeks for me. Plan on doing it tomorrow. Is that a steel plate behind the burn pot?
    ivanhoe, IHATEPROPANE, T-BONE and 4 others like this.
  3. Rich250
    Rich250
    Berks County PA.
    Cleaned mine Tuesday night when I knew it was gonna be shut down for sometime.
  4. wildwest
    I do not remember :emb: Only that I waited too long last time and the stove told me so at 1am in the morning.
  5. will711
    will711
    Pocono Mts.
    No it's the brick
  6. ttdberg
    ttdberg Pellet Pig
    CT
    Same here. Last major cleaning was two weeks ago, last 2 minute cleaning was this morning after it shut down, before I left for work.
  7. slvrblkk
    slvrblkk
    Northampton, PA
    Few weeks ago when I bought that air tank. Should make the end of the burning season at this point without a major clean.
  8. wildwest
    Remind me, did you use the LBT and an air compressor at the same time?
  9. slvrblkk
    slvrblkk
    Northampton, PA
    Correct!!!
  10. wildwest
    WWW wants to do that too.......
  11. subsailor
    subsailor
    Winthrop, Maine
    Is that like 1 big thick brick? I have 3 that go across the back of the stove. That looks like just 1.
    ivanhoe, bogieb, IHATEPROPANE and 4 others like this.
  12. will711
    will711
    Pocono Mts.
    Yes the p43 only has 1
    Russell, ivanhoe, bogieb and 4 others like this.
  13. jtakeman
    A while, I got clumps building on the burn grate, Maybe this weekend
    Ash pan is only about half full, So maybe just the burnpot?? Then do a full on come shutdown time.
  14. will711
    will711
    Pocono Mts.
    And for the record as filthy as this stove is it's still pumping out the heat no issues :dex: , I know it would be more efficient if it was clean :( peace of mind knowing that you can abuse the stove and it will still perform well. Harman :yes:
    gbreda, Russell, ivanhoe and 5 others like this.
  15. wildwest
    Guess I know what I will do this weekend.
  16. will711
    will711
    Pocono Mts.
    Me too;)
  17. eatonpcat
    Wwwwwwwhhhhhaaaattttt??????
    You have to clean Harmonicas??
  18. Harman Lover 007
    Harman Lover 007
    Eastern Mass
    Holy crap that is a mess. Mine has never looked like that....ever!
    Russell, ivanhoe and IHATEPROPANE like this.
  19. MikeSs
    MikeSs
    new have county, ct.
    Took the tee cleanout cover off in jan. Usually do that 2 times a season. Bang on the pipe to get a bunch more ash off then put cover back on.
    Side baffles removed every 2 weeks. A bit of brushing at the top cavities above the baffles.
    The occasional vac in the section behindthe firebox to the combustion blower.
    Then the daily or 2 quick cleanout with the vac.
    For some reason, my combustion blower does not hold much on it. How I know?
    I took it out for the first time last year (stove istalled around 1997) and there was little on it. Guess hardwood makes a difference?
    Never lbt it either.
    The tee is where i get the buildup and the flame tells me its time.
    I do stick the small vac hose in the exhaust and get some out of the combustion blower area.
    And I burn 2 to 3 tons a year.
    (psst. Dont tell the clean clean clean extremists on that other site)
    (Sorry for the book)
  20. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    YESTERDAY :D
    I mucked and sucked the little Whit yesterday afternoon with a quicky window wash too..
    Ran the little long handled bottle brush up its casting orifice and then leafered it until the air stream was clean.
    This stove has a very small ash pan area and with the shells it fills quickly.
    Weekly or even biweekly is needed to keep thing working well.
    Running the leafer at full speed really gets the draft fan screaming.
    Ahhh yess, a clean stove is a happy stove.
    Even with a good cleaning, the windows will show a dusting of a tan ash after just an overnight run.
    I have cleaned the air wash slots and all and it seems to be the way it works.
    The other piccy was taken a while back just prior to cleaning, note the buildup of crap on the windows
    Russell, ivanhoe, will711 and 2 others like this.
