Widowmaker video
Discussion in 'The Wood Pile' started by HDRock, Mar 24, 2016.
  1. HDRock
    Boy O boy a lot of things wrong in this video:wacky::hair:
  2. thewoodlands
    thewoodlands
    An indirect pull would be what I'd use.
  3. Smokinpiney
    Smokinpiney
    "South" Jersey
    Sooo so many things wrong in that video. :picard:. Guess that dude's never seen what a cable breaking under tension can do to a person. Especially at head height!
    Always, ALWAYS lay some sort of weight over the cable even if it's a rag.
  4. Star Gazer
    Star Gazer
    Right behind you
    Since it was hung up in another small tree, and that small tree will end up being a hazard tree (note the lean is further than 7 degrees), I would fell the small tree and kill two birds with one stone. (shallow face, then bore cut out) A definite no no for the steel cable.
  5. Well Seasoned
    That was squirrely.......
  6. HDRock
    That's a good word for it right there
    maybe he could get Bob Vila over there to help him out too:D
  7. Horkn
    DaveGunter
    Squirrel!!!!!!
    Lol.
    Yeah, that was scarier than it should have been.
  8. HDRock
    :D
  9. DaveGunter
    DaveGunter
    I'm awake!!
  10. WeldrDave
    Man, This video just has chunks of stupid flying from it! As Smokinpiney said, if you ever seen a cable snap "(I HAVE)" he would have maybe lost part of his scull or even his head. How about a simple back cut, let it crack and drop. Works every time!
  11. HDRock
    azz backwards:whistle:
  12. HDRock
  13. Stinny
  14. HDRock
  15. UncleJoe
    UncleJoe
    SC Pa
    I've never had a cable snap but I have had ropes snap. I would not want to be on the receiving end of a rope as all that energy is released. It could be just as deadly as the steel cable
    I saw this video a couple years ago.
    What an idiot! That tree didn't even come close to following the notch! Someone could get hurt following his directions.
  16. HDRock
    I had a 40ft chain snap, 10-15 feet ended up inside the back of my Grand Cherokee with the hatch open, good thing as I would have lost a window, but very scary the rest ended up under the Jeep, 40 feet of 3/8 chain smacking you in the side of head, OMG :hair:
    To top that, I saw images of a off roader Jeepster with heavy duty cable that snapped, all came back through the back window killed him in one second :eek:
  17. Star Gazer
    Star Gazer
    Right behind you
    He's even worse than the guy in the first video!
    Oh wait, that must be the new Triple V (Vila) method. A tight V 2/3'ds of the way through the tree. Then another cut resembling a Wide V with another tighter V on the bottom for the hinge. The wide V is to help guide the tree a full 90 degrees away from the first V. :loco: :crazy:
  18. ironpony
    ironpony
    Mid Ohio
    with all the wind we have a bunch of widow makers, not sure what to do about them.
    Horkn likes this.
  19. HDRock
    I just hope no one watches that video and thinks he knows what the frick he is doing
  20. ironpony
    ironpony
    Mid Ohio
    Bob is an expert..........ex is a has been, (s)pert is a drip under pressure.
